Installing BMR LCA's with or without a ramp.
Old Mar 10, 2006 | 05:53 PM
traffic142's Avatar
Thumbs up
I have read over 5 pages of LCA stuff. I have the following questions: [img]style_emoticons/<#EMO_DIR#>/headscratch.gif[/img]
1. Can you use a set of Rhino Ramps to back you car onto and leave the wheels on?
2. If you use ramps, do you have to jack up the front of the car to "Load" the suspension.
3. If you use jackstands on the rear and remove the tires, do you have to load up the suspension and if so how?
4. I have heard that Steeda has you use the ramps and not remove the tires, I have read that several have used stands for the BMR? which is it?
Maybe I am dense, but I am not sure which way to go about installing them now? [img]style_emoticons/<#EMO_DIR#>/banghead.gif[/img]
Old Mar 10, 2006 | 07:04 PM
Mongoose's Avatar
I put them on while it was on the lift for other work. No load, preload. Just do one at a time then do the panhard rod.
Old Mar 10, 2006 | 08:18 PM
mikem's Avatar
Just jack up and put jack stands under.You will have to undo the E-Brake cable wich is very easy.Self explanatory.......After the cars on the jacks just put the jack under the rearend lift it up a little and unbolt the LCA.s and replace that simple.
Mr. V
Dec 24, 2016 02:57 PM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
