Installed my Adj UCA today
After work I stopped by the auto hobby shop on base and changed my oil and put in my BMR adjustable UCA. It was going smooth untill I realized that I HAD to lower the fuel tank no matter what.
But I got it all settled out and its in now. Granted I dont feel a diff, because the LCA's got rid of the wheel hop, but this will help me get my pinion angle when I lower it and get a solid d/s.
John
Factory spec is pinion down 0.55 deg , but I think that is confusing and does not tell the whole story. Generally you want less than 2 degrees between the pinion and the driveshaft, pinion down relative to the drive shaft. Same apples to trans to driveshaft. drive shaft down 1 - 2 degrees relative to the transmission.
Is the angle measured with the car sitting on the ground under it's own weight? I assume it is, just trying to make sure. Anyone have a write-up on installation of LCAs? Installing BMR LCAs this December.
Wheels on the ground, at least a half a tank of gas, and something representing your weight in the driver seat. This will give you the best measurements and settings.
I have not checked, but check Taco Bills list of DIY's. I think the only thing he has left alone and not documented modifying is the 12V accessory outlet on the dash.
Only hint I can give you is only change one side at a time and torque to factory spec's. Preferrably new nuts and bolts. There is a write up out there, saw it not that long ago.
THEN take the car for a ginger test drive, listening for new clunks or squeeks, and re-check the torque on the mount bolts. Once all is good, drive it like you stole it!! Offset box wrenches in 18 and 22MM make life easy doing this install...
SMBJoshy
8/16/15 02:48 PM
