Installed JLT CAI and 93 tune
Old Jun 19, 2005 | 10:29 PM
wild stray's Avatar
O.K., they say the memory is the first thing to go and I think I do remember having to reset the radio!
Satin Silver 05's Avatar
disconnect your battery and you will see.
Old Jun 20, 2005 | 08:11 AM
ILikeBond's Avatar
I've tried disconnecting my battery like 3 times now and have been unsuccessful - I can easily disconnect the ground wire and the positive (red), but the negative is held into the battery with a pin - how do you do this? When I disconnect just the positive (and left it disconnected for ~ 2 hrs), I came back and the clock was fine, radio presets had not been erased, etc. What am I missing here? :scratch:
Old Jun 20, 2005 | 08:37 PM
you only need to remove the positive side. leave disconnected for 20 minutes.
Old Jun 20, 2005 | 08:43 PM
ILikeBond's Avatar
I did that. Kept it disconnected for 2 hours. Clock and radio settings remained the same.
Old Jun 20, 2005 | 10:27 PM
you removed the large red wire on the fender side of the battery...........The vertical 10mm bolt, and pulled off the terminal? after disconnect there is no power inside the car, lights no work? if this is the case you have some freak car. the steps to do this are in the woners manual. :scratch:
Old Jun 21, 2005 | 08:11 AM
ILikeBond's Avatar
Yeah, exactly - unscrewed the bolt, took the red terminal off, made sure it wasn't touching anything - go back in the car, lights, radio, cd player, remote lock/unlock, etc., all still works - and continues to be working 2 hrs later. WTF?? :scratch:
Old Jun 21, 2005 | 08:28 AM
y22kc's Avatar
When I disconnect the power, I disconnect the negative wire from the battery. It has reset the computer everytime.
Old Jun 21, 2005 | 09:32 AM
Redfire 05Gt's Avatar
Anybody need a spare battery?? I think Jack has one he doesn't need. LOL
Old Jun 21, 2005 | 09:33 AM
Hey Jack, did you get that new glassback roof with solar power option??
Old Jun 22, 2005 | 03:52 PM
zinn's Avatar
For safety you should allways disconnect the negetive side first. Since the whole chassis is connected to the ground you run a risk of shorting the positive terminal to the chassis ground with a tool until the negitive terminal has been disconnected. the risk might be minimal but it's a good pratice to get into the habit of.
you only need to dissconnect one battery terminal positive or negetive to dissconnect power.
if you dissconnect a terminal and still have power you either
1. dissconnected something other than the battery
2. have a second source of battery power such as a large cappacitor used for big aftermarket sound systems installed in your car. (the shaker might even have a capacitor)
I'm not sure if a capacitor would really have enough stored energy to run lights and stuff for long but they do store enegry like a battery.
Old Jun 22, 2005 | 08:00 PM
Agreed on the negative side, my bad for instructing otherwise. Thanks for pointing that out.
Old Jun 22, 2005 | 08:03 PM
ILikeBond's Avatar
OK, so can someone write out "How to Disconnect the Negative Side for Dummies"? It appeares to be crimped in to the terminal, which is in turn bolted to the battery... I can't figure it out.
Old Jun 22, 2005 | 08:29 PM
Mongoose's Avatar
You must have a connection none of us has. Mine just has one metric nut to loosen. Sometime its better to leave things alone when you do not have a clue than screw it up. Battery notation After battery is disconnected I turn on a light or open a door and no more memory in clock radio or what ever. Ford tech told me that. Have not tested it yet.
Old Jun 22, 2005 | 08:33 PM
ILikeBond's Avatar
OK, now I gotta take a picture... I'll go do it in a little bit. If I'm looking at/toying with the right things (and I think I am), I can remove the ground wire and the positive terminal by simply loosening one metric nut - but not the negative cable.
Pic to come...
Old Jun 22, 2005 | 10:13 PM
ILikeBond's Avatar
OK, here are a couple pictures.
I'm nervous about my stupidity being pointed out to me...
... but - look at the negative terminal. The copper wires are "crimped" into a plate that held under a metal bracket which is bolted and pinned into the battery - I can't figure out how to disengage the terminal.
The positive side has a simple nut holding the terminal to the plate (rather than being "crimped" in). The ground wire is also held by a simple bolt - but I didn't take a pic.
Old Jun 22, 2005 | 10:14 PM
ILikeBond's Avatar
Negative...
Old Jun 22, 2005 | 10:18 PM
ILikeBond's Avatar
While I'm at it - hope no one minds - I'll throw a few pics up from last Friday when I was having work done on her - gears installed, x-pipe, steeda UD pulleys and dyno'd.
Work done at Mustang Magic (www.mustangmagicinc.com) in Deer Park, Long Island. (NY)
Old Jun 22, 2005 | 10:23 PM
wild stray's Avatar
How'd she do on the dyno with the new mods?
  #40
ILikeBond's Avatar
X-pipe - was going to do it myself, but crawled under the car and saw I'd need to cut the stock tubes behind the cats. Didn't have the tools or clearance to do it myself, so I just had them do it. Combined with SLPs, it really adds a deeper, more throaty note, and I can feel it rumble under my feet under acceleration. Not too loud or obnoxious. I'll try to load a sound clip at some point.
