Installed Champion Plugs
Old 5/19/08 | 09:19 PM
  #301
randy_tho's Avatar
For the anti-seize does it need to be Nickel based or can it be the normal anti-seize spec'd for aluminum engines?
Permatex® - Anti-Seize Lubricant - NFPA Fire Code 30B Level 3 A heavy duty blend of aluminum, copper and graphite lubricants in a petroleum base. Use during assembly to prevent galling, corrosion and seizing and to assure easier disassembly. Inert, will not evaporate or harden in extreme temperatures. Salt, corrosion and moisture resistant. Temperature range -60°F to 1600°F (-51°C to 871°C). Non-aerosol version meets Mil Spec A-907. Suggested Applications: Boiler and oven parts, gears, chains, cables, sprockets, levers, pivots, rollers, valve stems, jet engines, industrial turbines.
or
Permatex® - Nickel Anti-Seize Lubricants Protects metal parts from seizing and galling at temperatures of to 2400°F (1316°C). Copper-free, use under conditions of extreme pressure and temperature and with stainless steel, titanium and nickel alloys. Suggested Applications: Drop forge dies and hammers, catalyst bed and reaction chamber supports. Slow rotating bearings in hot corrosive environments. Lubricate and seal pipe threads in acid environments. Coat gaskets in high temperature applications. Lubricate conveyor chains, chemical plant bolts for pump housing and pipe flanges.
Seems like either would be fine?
Old 5/19/08 | 09:28 PM
  #302
Boltzman's Avatar
also got to be careful not to put too much anti seize on..
Old 5/19/08 | 09:38 PM
  #303
surf808's Avatar
I used the Nickel one. The TSB says to use the motorcraft anti seize which has a temp rating of 2400 or something. So you should use something close to that.
Old 5/26/08 | 10:23 PM
  #304
Kenichi Mifune's Avatar
The Ford stuff is rated up to 2600 F.
Old 5/27/08 | 03:14 PM
  #305
Thomas S's Avatar
Ok I read the entire thread. Let me see if I have this straight:
I have 20+k on my car and I'm still under warranty. I should replace the stock plugs asap per the TSB with Champion 7989s(everyone is in agreement that those are ok) and I should use a light coat of anti-seize in the location specified in the TSB and gap them at .054? You guys are scaring me so I'll be very careful and use the Ford carb cleaner and anti-seize.
Thanks to all for this information.
Old 5/27/08 | 03:43 PM
  #306
surf808's Avatar
I gaped mine to .045. The acceptable range for the stockers are .04-.05.
Old 5/27/08 | 05:44 PM
  #307
70MACH1OWNER's Avatar
I would agree with this. The gap will only get bigger with time. I also have about 23K miles on my car and all this talk about plug breakage has me worried. But I was thinking of going with the Brisk plug. So I will pose this question. If money is not a consideration...what is the best one piece plug for us to use? If it is Champion than that is what I will go with.
Scott
Old 5/28/08 | 03:43 PM
  #308
mbishop1279's Avatar
I am running the Champions gaped at .045 and Motorcraft Anti Sieze with no problems. I had 5K on my plugs when I pulled them. Just do not weant the M/c plugs breaking off in the heads.
Old 5/28/08 | 04:42 PM
  #309
seabiscuit's Avatar
I am running the Champions gaped at .050 exactly how the M/C pulled out at 22K were gaped - car run perfect. no problems at all and I do not have nightmares with braking plugs
Old 5/29/08 | 09:59 AM
  #310
ronslakie's Avatar
If anyone finds a decent price on the Champion spark plugs (#7989) please post it. Both Rock Auto and Summit have now increased their prices to $13 -$16 each and I saw one wholesale sight where their cost is about $4.50 each.
Old 5/31/08 | 10:38 AM
  #311
I am running the Champions gaped at .045 and Motorcraft Anti Sieze with no problems. I had 5K on my plugs when I pulled them. Just do not want the M/c plugs breaking off in the heads.
Old 6/23/08 | 12:38 PM
  #312
Preach's Avatar
Summit racing has them for $12.98. I just installed them after the fun with the Motorcraft plugs.
No complaints!
Old 6/23/08 | 06:43 PM
  #313
randy_tho's Avatar
Did you notice any of the manufacturing "variances" that have been reported? How many miles with them so far?
No complaints!
Old 8/12/08 | 11:40 AM
  #314
goldenpony's Avatar
Plug Nightmare
Originally Posted by jwooski
and if you find one not coming out then take it into your local ford dealer
I followed the TSB to the letter. The second plug I tried snapped. I did take it to my Ford dealer , their trained Tech broke off 5 more. 38K miles on the clock.
Now running Champions gapped at .044" and couldn't be happier. I have over 5K miles on the Champions and car runs better than ever.
Old 8/12/08 | 12:38 PM
  #315
cave diver's Avatar
I've been running the Champion #7989 plugs for several months now. I set a .045 gap, put a very light coat 2,600 degree high-temp nickle anti-seize on the upper 1/3 of the grounding shield and a very light coat on the threads as well. They car runs great with them, not a single problem. Out of curiosity I took out a couple of the Champion plugs 2 weeks ago and they came out very easy and looked fine with no build-up on the grounding shield.
Old 8/13/08 | 01:51 AM
  #316
jamesdem1123's Avatar
anyone know the champion part number for the feb 08 and up plugs?
Old 8/13/08 | 05:09 AM
  #317
cave diver's Avatar
From what I understand, they changed the head design on the 4.6 in Nov. 07 and it now has a traditional 1-piece plug (different size plug than on the pre-Nov 07 heads). I don't think you need to change yours out.
Old 8/13/08 | 07:13 AM
  #318
sweet! ill still need one step colder plugs for nitrous but at least i can use factory style plugs. good stuff
Old 8/14/08 | 08:48 PM
  #319
randy_tho's Avatar
Probably would be smart to pull one and see for yourself. You'll know because the new style is not an HT plug.
Old 8/25/08 | 09:12 PM
  #320
n8rfastback's Avatar
hey guys are the new autolite HT1 plugs one piece????
my dad bought 8 of them on accident, and doesnt need them, so if they are 1 piece than he will give them to me.....
he said they are 1 piece but i dont think he knows the diff.....
i need to know asap before he returns them...
lol
