Installation of Bassani X-pipe w/o Cats-
I was planning to install the Bassani X-pipe this weekend (keeping the stock cats - I ordered just the X-pipe part). Poking around I see some talk of sawing the stock H-pipe out and welding in the X-pipe. I thought it was a bolt-on. The sawing and welding scares me. Is this actually what needs to be done? If so, I probably have to take it to a pro...
If it does need to be welded, why does it come with 4 brackets? Just doubling up the connection?
Thanks!
Thanks!
It is not necessary to weld it in. It is made to clamp in place, which is totally fine. Some people might decidee to spend the extra money/time and get it permanently put in, by welding it. Either way works just fine.
-Andy
-Andy
-Andy
-Andy
So for sawing it out, I probably just want to measure where the X-pipe would fit in and then leave an extra inch or so for overlap? Slide it in one end, tighten it down a bit, then slide it over the other, center it, and tighten all four sides down real tight then?
Originally posted by Kluski@June 10, 2005, 10:08 AM
Is there much gain in power by still using the stock cats as opposed to using the high flow cats.
Originally posted by My Blue Heaven@June 9, 2005, 3:55 PM
NO cutting is needed. Everything bolts up, from front to back.
I was going to leave the stock cats but when Bassani overshipped me I and gave me the cats too I just put them on. In 2 years when I get an emissions test I am going to put the stock cats back on. Hopefully it won't be all welded up just from the heat of driving by then. ^_^
Originally posted by swingle007@June 15, 2005, 7:12 AM
Yep, sawing will be required if it's just the x-pipe and some axle backs...same setup I have.....
John
John
Yeah, I paid a local speed shop to do the exhaust for me....the sound is much more throaty with the X and I picked up a good amount of torque from it...was a lot easier to break the tires at 40mph then it was before so it passed the seat of the pants power gain with me.....I bought mine way back before the high flows were available so I had no choice, but I love the sound and would think you would as well.....Hope it works out!
John
John
John
John
9/10/15 12:44 PM
