Install problem driveshaft
Old Jun 24, 2010 | 07:37 AM
kawazakske's Avatar
I've put a Steeda 1piece alu driveshaft under my 2005 GT.
When heavy accellerating, the driveshaft touches the bottom of te car in about the middle of the driveshaft . Did I something wrong ?
Peter
Old Jun 24, 2010 | 07:42 AM
Casey4s's Avatar
No probably not, mine did that when the suspension bottomed out on a bump or dip. After a a month I pulled it out and saw (on the shaft) where it was bumping and worked it over with a hammer. There is a little unused bracket or something as I remember.
Old Jun 24, 2010 | 08:15 AM
kawazakske's Avatar
Thanks, i hoped it was something like that. Tomorrow I 'll take him back off.
Old Jun 24, 2010 | 08:49 AM
05YellowGT's Avatar
I have one on my 05 that was installed by Steeda and mine has never hit anything , so I would call them and ask ...
Old Jun 24, 2010 | 09:41 AM
kawazakske's Avatar
Maybe these might help
http://www.cjponyparts.com/steeda-lo...010/p/5558119/
I've got the steeda billet lca's
Old Jun 24, 2010 | 09:53 AM
Casey4s's Avatar
Is your car lowered?
Old Jun 24, 2010 | 09:54 AM
tom281's Avatar
Check your pinion angle, you may need an UCA to adjust it.
Old Jun 24, 2010 | 11:00 AM
If it's a 4" DS, I'm guessing it's hitting the center hump in the trans tunnel. If so, do as Casey4s suggested. DS will have to be dropped to get to that area.
I don't think the LCA's have anything to do with this issue.
Old Jun 24, 2010 | 11:24 AM
05YellowGT's Avatar
The Steeda shaft is tapered , and like I said mine doesn't hit or rub against anything. My car is lowered with the Steeda Sport springs and I also have their Billet LCA and relocation brackets , but not the adjustable UCA. If it's hitting on your car then it seems to me there must be something wrong ...
Old Jun 24, 2010 | 11:29 AM
Dysan's Avatar
My powerhouse driveshaft did the same thing on my car. My car is stock ride height and the pinion angle was correct, I just get a ton of traction when launching at the track. All I did was take the d/s out, cut out that bump down area in the tunnel and it's been fine since.
Old Jun 24, 2010 | 11:58 AM
Casey4s's Avatar
If I remember correctly, it was hitting where the center bearing was for the 2 piece.
Ecostang
Nov 3, 2022 08:50 PM
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
iceD
Apr 10, 2016 12:59 PM
SMBJoshy
Aug 24, 2015 10:55 AM
