Innovate a/f gauge trouble shooting
Old Dec 29, 2012 | 11:04 PM
Victorfriessen's Avatar
Today my innovate gauge started to show 21.5 and 7.5 and suddenly it goes to 8.5 and bak to 7.5 , what could cause this?
Old Jan 2, 2013 | 08:49 AM
05YellowGT's Avatar
Try doing a recalibration and check you grounds , or maybe the sensor is going bad. I had problems with mine a few years ago , it would give false readings and sometimes an error code after stopping for a short time when I restarted the car. I at first thought it might be heat soak on the sensor , since it only happened after the car set for a while and was hot. But it turned out my battery was going bad and when it sat for a while and soaked up the heat it didn't have enough voltage for the sensor to give a good reading.
Old Jan 2, 2013 | 08:57 PM
TTS197's Avatar
Check the ground the inovate's are notorious for this.
Old Jan 3, 2013 | 04:37 PM
Im gona check that and recalibrate the sensor and lets cee if that will work
mx5jhb
Sep 30, 2015 04:44 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
