Idle problems
Old Jul 10, 2008 | 09:26 PM
ryan1112's Avatar
Idle problems
As the title says I have idle problems. About 50% of the time when I hit the clutch the rpms drop faster than normal and the idle goes down to about 300 rpms or less. It almost stalls. I have a clean air filter and a new fuel filter. I have a K&N air charger with SCT2 tune which has been fine for 2 years. I even set the idle to 850 rpms and it still bounces around. I made sure the hose on the k&n and the brake booster are connected correctly. I'm stumped.
Anyone have any ideas? Could it be the throttle body?
Old Jul 10, 2008 | 10:01 PM
randy_tho's Avatar
I'd look at the throttle body and see if it is clean. Do these cars have a regular ISC? Maybe it is dirty? If the TB is clean it should be too though.
Old Jul 11, 2008 | 06:10 AM
ryan1112's Avatar
Well, I cleaned the throttle body about a month ago. After using the search function I have seen that a few others have had this problem and it might be the throttle position sensor. Is the sensor easy to replace?
Old Jul 11, 2008 | 06:48 AM
tdbrown75's Avatar
You should also check for a vacuum leak, I had one around my MAF and was experiencing similar issues to yours. Make sure all your connections are tight and secure.
If you want to try the TPS route, I have one I can sell you. They go for about $80 at the dealership. You can have my gently used one for $35 plus shipping. It happens to be up on eBay right now, seller name is tdbrown75.
Tim
Old Jul 11, 2008 | 06:53 AM
05YellowGT's Avatar
I was having problems with my A/F ratio being lean and Steeda determined that I had a bad throttle body and replaced it. Prior to that I had started having idle problems like you describe and when they replaced my throttle body it also cured the idle problems ...
Old Jul 11, 2008 | 03:52 PM
TillmanSpeed's Avatar
Former Vendor
Have your tuner check the dashpot, isc/idle settings.
CR
Tillman Speed, Inc.
www.TillmanSpeed.com
Old Jul 11, 2008 | 06:36 PM
ryan1112's Avatar
CR
Tillman Speed, Inc.
I will ask him about it on Monday.
Thanks.
Old Jul 11, 2008 | 08:21 PM
2kanchoo's Avatar
Agreed. Also make sure your MAF sensor is clean.
Old Jul 14, 2008 | 06:35 PM
ryan1112's Avatar
Well, I just got home and the engine when into failsafe and I got an engine light. I used my SCT to read the codes and they are:
P2106 Throttle Actuator Control System - Forced Limited Power
P2132 Throttle/Pedal Position Sensor/Switch "F" Circuit Low Input
I would assume that I need to order a new throttle position sensor. Are they easy to install?
Old Jul 14, 2008 | 07:13 PM
tdbrown75's Avatar
Super easy, two screws! I dropped my eBay listing to $20 for the sensor if you want it (Item number: 290245794436), I paid nearly $80 for it when I thought mine was going bad. In my case it ended up being a vacuum leak, but I did not throw codes like you have.
Tim (tdbrown75)
Old Jul 14, 2008 | 07:20 PM
ryan1112's Avatar
Can you give me a link to your listing? I can't find it since I'm retarded. lol
Old Jul 14, 2008 | 07:23 PM
ryan1112's Avatar
So you put the old one back in? How many miles are on the new one?
Old Jul 14, 2008 | 07:25 PM
tdbrown75's Avatar
PM Sent.
Tim
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
Airborne42
Sep 24, 2015 11:01 AM
