Hurst shifter, BMR driveshaft loop and Spydershaft Problems
Old Feb 26, 2008 | 07:30 PM
btrokc's Avatar
Anyone have the above combination and problems. I am having problems. Recently installed a BMR ds loop (the one with the big ring) and a 4" Alum Spydershaft. I already had a Hurst shifter. Now the loop hits up against the shifter and when I go over a bump, I get loop to driveshaft contact. Believe some mods on the loop arm may solve the problems. Any ideas.
Old Feb 26, 2008 | 07:40 PM
GRAYPNY's Avatar
Most of us that have an aftermaket shifter, BMR brace and Spydershaft had to fab up a spacer to go between the bracket on the brace to shim it away from the shifter. I put a piece of metal, can't remember the width in there and the problem was solved. Good luck.
Old Feb 26, 2008 | 08:01 PM
LEO_06GT's Avatar
Check out Tacobill's D/S install and scroll about halfway down. You'll see pics of the spacer he fabricated.
http://forums.bradbarnett.net/showth...373#post975373
Old Feb 26, 2008 | 09:20 PM
anthony05gt's Avatar
Taco Bill looked like he was under that car with only the jack supporting the rear of the vehicle.
Old Feb 26, 2008 | 11:56 PM
LEO_06GT's Avatar
Nope. In fact he's usually got one jack under the pumpkin, one on the center of the k member. Then two jacks on both ends of k memeber and two jacks just behind the rear factory jack points. I know because I do all my installs at his place and the 2 jack, 4 jack stands is SOP.
Old Feb 27, 2008 | 12:33 PM
WayneA's Avatar
I had the same problem with the stock shifter hitting the BMR loop in 1st, 3rd and 5th. I used the 2 spacers from where the center portion of the stock two piece shaft is attached to the underbody. I believe the spacers are about 7/16” thick. I have a 3 1/2” aluminum DS so no issues with the loop contacting it.
Old Feb 27, 2008 | 12:43 PM
Flat plate shim is more stable than using 2 washer spacers.
Whichever method you decide, a shim of 0.380" thickness should do the trick.
Nope. In fact he's usually got one jack under the pumpkin, one on the center of the k member. Then two jacks on both ends of k member and two jacks just behind the rear factory jack points. I know because I do all my installs at his place and the 2 jack, 4 jack stands is SOP.
C'mon Anthony, I'm supposed to be the one setting the standard here.
Old Feb 27, 2008 | 01:35 PM
WayneA's Avatar
I would have to agree, I'm just too lazy to make one. Anyone know where I can get a piece of 7/16" thick aluminum to make a one piece shim???
Old Feb 27, 2008 | 01:53 PM
btrokc's Avatar
Guys. Shim worked. Thanks to all for the help.
Rando
Aug 25, 2021 11:12 AM
Jul 8, 2016 08:53 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
