Hurst Shifter
Old Oct 3, 2007 | 10:02 AM
Rotormd's Avatar
Hurst Shifter
Can the Hurst shifter be installed without removing any exhaust or Tranmission components, and is this a easy job?
Old Oct 3, 2007 | 10:39 AM
WaltM's Avatar
Yes.
http://www.fordmuscle.com/archives/2...fter/index.php
Old Oct 3, 2007 | 11:07 AM
subzero05's Avatar
Yes, and if you are looking for one let me know...=)
Old Oct 3, 2007 | 11:37 AM
ramairgt1's Avatar
I say its a 2 out of 10 on the PITA scale. Make sure you use loctite on the bolts or you might be sorry down the road.
Old Oct 3, 2007 | 12:21 PM
WaltM's Avatar
The biggest pita is the fact that you have to get the car in the air. Everything else is pretty straightforward.
Old Oct 3, 2007 | 01:01 PM
FLAstangx3's Avatar
Easy, but a third hand is very helpful!
Old Oct 3, 2007 | 01:31 PM
kh765's Avatar
Old Oct 3, 2007 | 03:46 PM
cop on my back's Avatar
Don't use the allen head bolts supplied, you can't get them tight enough and even with loctite they will come loose. I put hex head bolts in with loctite and they have stayed tight ever since.
Old Oct 3, 2007 | 03:53 PM
officespace56's Avatar
you dont need to get the car in the air, jackstands work fine
Old Oct 4, 2007 | 05:48 AM
FLAstangx3's Avatar
Originally Posted by kh765
Not so. Just try dropping the shifter through the hole and starting the boltup, without a hand up top.
Old Oct 4, 2007 | 09:27 PM
Fun4Me's Avatar
Put mine in today. It took just over an hour. However, be aware of the directions. Mine were old and had the offset on the passenger side. THIS IS WRONG. After installing per the directions, I called the Hurst tech line and confirmed that the offset should be on the driver's side (should have called 1st but that's what happens with poor planning).
I like the "notchy" feel of the engagement but it will take a while to get used to the effort to put it into gear.
Old Oct 5, 2007 | 08:32 AM
sleeper2's Avatar
The shifter install is pretty straight forward. I had my car on ramps, and it was cozy, but I could get underneath to do it. From above, I dropped the whole shifter including my hand all the way down through the hole, then pulled my hand back, still holding onto the stick. Went in like a charm that way. A ratcheting box wrench will save some time on the front bolt, just don't trap the wrench with the bolt, switch to the open end after a bit. Enjoy your shifter!
Sleeper2
Old Oct 5, 2007 | 06:49 PM
1550GT's Avatar
The install is pretty easy. I got mine from subzero05. You should contact him if you do not have the shifter yet. It would be very worth your while to do so.
jim010
Jun 24, 2024 04:23 PM
Jul 8, 2016 08:53 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 16, 2015 06:44 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
