Hp hp hp
Old Mar 31, 2011 | 09:07 AM
zcgstang's Avatar
Hp hp hp
I know this has got to be posted all over the place but I drive a 06 gt. Currently im running pypes axle back, sct tuner and jlt cai. My goal is to be at 350 rwhp. Now I might have 350 to the crank but thats not what im going for. Can anyone give me bolt on advice to get me here? I can't afford s/c or turbo
Old Mar 31, 2011 | 10:16 AM
Gtpony325's Avatar
I have 337rwhp. Nothing but bolt ons. Mods are
Steeda charge motion delete plates
Bbk throttle body
Airaid cold air intake
Steeda underdrive pulleys
Pypes full length headers w/ catless x pipe
Pypes violator mufflers
Sct tune
Ford racing hot rod cams
3.73 rear gear
1 piece aluminum drive shaft
Old Mar 31, 2011 | 10:22 AM
zcgstang's Avatar
Bbk throttle body
Sct tune
3.73 rear gear
Man thats quite a list...i have some serious work and money making lol how do you get your car inspected with catless?
Old Mar 31, 2011 | 10:39 AM
Gtpony325's Avatar
I havent had to have the emissions done yet but the way it works in illinois they just plug into the computer and runs a diagnostic to see if there are any codes stored. When i had the car tuned i had the rear 02 sensors turned off so the code wouldnt show up. Should pass just the way it sits
Old Mar 31, 2011 | 10:41 AM
zcgstang's Avatar
Now if I have my hand held tuner can I go turn them off so If I wanted to go catless I can pass?
Old Mar 31, 2011 | 10:55 AM
Gtpony325's Avatar
I do believe you should be able to turn them off on your own. I had mine turned off when i had it tuned. I know that you said that you wanted to make 350rwhp but depending on what your budget is it could take quite awhile to get there. Parts for our cars are still expensive.
Old Mar 31, 2011 | 11:25 AM
zcgstang's Avatar
Thats what im thinking...i should probably start saving for a blower
Old Mar 31, 2011 | 12:16 PM
05YellowGT's Avatar
I not absolutely sure , but I don't believe you can use the tuner to turn them off your self. Who ever did your tune will need to turn them off and load that into our tuner and then you reload the tune ...
Old Mar 31, 2011 | 12:23 PM
zcgstang's Avatar
I have lifetime tunes from bama threw AM but if I get an xpipe I can call them and they can email me one in
Old Mar 31, 2011 | 01:18 PM
Gtpony325's Avatar
Sounds like a good plan there.
Old Mar 31, 2011 | 01:23 PM
zcgstang's Avatar
I know right? AM takes care of ya! What im worried about is that an off road x is with my axle backs, itll sound insane loud
Old Mar 31, 2011 | 01:27 PM
69Mach1-409's Avatar
In NJ they just plug into the OBDII as weel, and if you tune off your rear O2's it will not pass. I kept my stock Mid-pipe for just that reason.
Old Mar 31, 2011 | 01:33 PM
Gtpony325's Avatar
I know my friend tood his for emissions without his cats on and he passed with the rear 02 sensors turned off. I do have my stock mid pipe also just in case i do fail my emissions test
Old Mar 31, 2011 | 01:59 PM
zcgstang's Avatar
Here in tx they do it through the comp or whatever. My good friend drives a 01 cobra I believe and he has no cats. He turned his off and they passed his
Old Mar 31, 2011 | 07:23 PM
zcgstang's Avatar
Do any of yall think a throttle body spacer is worth it? How about udp?
Old Mar 31, 2011 | 07:31 PM
karman's Avatar
Wink
TBS=NO
UDP=YES
But if you save your money for a blower don't bother with either.
Old Mar 31, 2011 | 07:42 PM
zcgstang's Avatar
Originally Posted by karman
TBS=NO
UDP=YES
That won't be happening tilll I'm much older. Sorry to ask, but what is it that upd's actually do?
Old Mar 31, 2011 | 08:18 PM
Gtpony325's Avatar
I have under drive pulleys. As far as i kno they dont really free up that much power. Same goes for the throttle body spacer. Doesnt really free up any horsepower that i know of.
Old Mar 31, 2011 | 08:20 PM
zcgstang's Avatar
Any suggestions for me then without breaking the bank?
Old Apr 1, 2011 | 06:57 AM
stelthy77's Avatar
350 whp is my goal as well, you will need almost every basic bolt on to get there:
  • You already have the intake and tuner.
  • Under Drive Pullies (they DO make 5-8 hp) ($200)
  • Charge Motion Delete Plates (another 5-8) ($250)
  • Long Tube Headers ($500-$1200)
  • X or H pipe to go with the headers, you can get this with or without cats, for max hp without cats is best, and depending on who you ask, a X pipe might get you 1 or 2 extra HP over an H. ($200-450)
  • The best Cams you can afford (many options here, some require much more investment in terms of installation {Springs Required vs. No Springs Required}, but will get you a couple more precious HP) ($600-$900 + $$$ for installation)
  • A very good tune with the highest octane gas you can get (hopefully 93) ($300-600)
That should put you very close to 350, but you might still be 10 hp or so short, depending on your tune and how aggressive your cams are. (and depending on the dyno)
You could always get a throttle body or electric water pump to get the couple of extra HP. If you really wanted to be sure, ported heads ($$$$) will get you there along with all of the above.
Oh yeah, don't forget safely putting that power down and slowing down with all that extra go. Suspension, Brakes, and Tires will all be important to...
