How Do I Find My Gear Ratio ?
Old Feb 27, 2007 | 11:35 PM
GottaHaveIt's Avatar
Well I want to get me some Bama and it asks for gear ratio ? not on the sticker and I'm getting too tired to look so I'll go to bed, But if anyone would know how for me to locate this I really would Appreciate it alot !
I have a 2007 GT/CS Vert Manual 4.6 litre. Thanks Ed
Old Feb 27, 2007 | 11:52 PM
theedge67's Avatar
You either have the 3.31, or 3.55. For 2007, the 3.55 was optional, and cost $100 extra, otherwise the 3.31 is standard. If that doesn't help, you can always look under the rear end of the car, there is a tag on the rear diff. cover that tells the axle ratio.
Old Feb 28, 2007 | 02:21 PM
RedDragon777's Avatar
1. is it auto or manual
2. if it is auto it is 3.31 or just type stock
3a. if it is manual check your window sticker
3b. if there is nothing then you have 3.31 gears
3c. if you see 3.55 gears on the options side then you have 3.55 gears
4. you can look at the gear housing under the car and there should be a sticker that says
Old Feb 28, 2007 | 04:03 PM
neil07gt's Avatar
Open the driver door and look at the dataplate. Find the axle code and that will tell you.
AXLE code:
BG = 3.31 non-limited slip, base vehicle with manual or auto
CD = 3.55 limited slip, GT with manual
CG = 3.55 limited slip, GT with auto
Old Feb 28, 2007 | 05:07 PM
SteelTownStang's Avatar
AXLE code:
Neil is right on...
Old Feb 28, 2007 | 05:31 PM
yeah but he has a 2007, in 2007 the GT with manual had 3.31 stock and 3.55 optional and my GT came with 3.31 gears and it is an auto and mine is a 2006
Old Mar 2, 2007 | 06:49 PM
rdw401's Avatar
AXLE code:
Sorry to differ, but my sticker says CG, and I have a manual with a 3.55 limited slip.
CiniZter
25
Apr 28, 2016 05:41 PM
AMAlexLazarus
Oct 15, 2015 11:06 PM
Rando
Sep 30, 2015 12:28 PM
GMAYS
Sep 10, 2015 06:19 AM
