How to achieve 600rwhp?
Old Dec 11, 2012 | 08:20 AM
Victorfriessen's Avatar
I have a centri Supercharger on my 08 Mustang Gt,whats the next step to achieve 600rwhp?
What fuel pump works for this?
Old Dec 11, 2012 | 10:05 AM
AlsCobra's Avatar
A Man Just Needs Some....
Depends what blower and having enough fuel. Not sure if that bottom end will support 600hp though. Gonna take a pretty big blower too.
Old Dec 11, 2012 | 10:22 AM
Would a paxton 2200 intercooled handle it?
Old Dec 11, 2012 | 01:06 PM
retfr8flyr's Avatar
I posted this in your thread on another forum but I'll post here also. You can make 600 with your NOVI at a higher boost level, you're limited to about 18#'s of boost on pump gas. You will need a better mas air, your Mafia wont cut it at 600 hp.
You will need a forged bottom end and better fuel system. I don't know what injectors you currently have but you will need at least 60# injectors, 80# would be a better choice, for 600 hp. A GT500 fuel system would get you close but will be maxing out at 600, you will need bigger pumps or a boost a pump. I would recommend giving these guys a call about their stage II, or III fuel setup. http://www.sandhperformance.com/?page_id=48 They make great systems and can fix you up low budget or high budget setups.
You are also going to have to look at your drive train with that much HP. The 5R55S is going to need to be upgraded but it will still be at the limits at 600 and will not hold up for long. You would be better off selling the 5R55 setup and going with a built 4R70W then you would be pouring money into the 5R55.
Earl
Old Dec 11, 2012 | 02:37 PM
AlsCobra's Avatar
You really have to weigh your options. How much is your car worth and how much 600hp will cost you. Might be worth your wild to upgrade cars. Just a thought.
Old Dec 11, 2012 | 04:19 PM
70MACH1OWNER's Avatar
Your going at it backwards. If you don't start with a built bottom end to support that HP it doesn't really matter what supercharger or turbo you use. It won't last for long. Don't get me wrong...your goal is achievable very easily. Just not on the stock block.
Old Dec 11, 2012 | 06:08 PM
Kevin509's Avatar
Agreed. It seems like 450 at the wheels is sort of the safe limit most people recommend for the stock internals.
That's not to say that there are not people making more power than that reliably on stock guts, and there are people who have blown up there motors at 350 wheel horsepower. But long story short, if 600 whp is your goal, you need a built motor. Or like Al said, you need a platform like a GT500 or something that can make that sort of power.
Old Dec 11, 2012 | 07:24 PM
maldoj2's Avatar
victorfriessen i'm bulding my motor with the same goal as use, this is what i have
mmr short block
stage 2 heads
stage 2 blower cams
5/8 headers
ford racing manifol
return fuel system
paxton 2200 ho
mcleod rst clutch
10%od pully
snow meth
Old Dec 12, 2012 | 01:15 AM
Can I get away with forged pistons and rods or is the crank a weak point on these cars also?
Old Dec 12, 2012 | 05:11 AM
retfr8flyr's Avatar
The stock crank is a fairly strong piece. You can meet you 600 HP goals with the stock crank as long as you limit your rpm to below 6500. The stock crank doesn't have the extra counter weights that the forged crank does and will not handle the higher rpm's well.
Earl
Old Dec 12, 2012 | 08:59 AM
Well considering that your at full boost you rev your engine above 6500 rpm? What happens with the valves dont they start to float at that speed?
Old Dec 12, 2012 | 09:41 AM
bob's Avatar
bob
Nope, closer to 6600 or 6700 rpm. Ford rates their valvetrains 400 rpm over the rev limiter, after that it gets interesting.
Old Dec 12, 2012 | 11:35 AM
Any brand to consider the best in forged internals that other have had good luck with?
Old Dec 12, 2012 | 11:58 AM
retfr8flyr's Avatar
You can't go wrong with Manyley brand. Their H beam rods are the industry standard. For pistons I would recommend Manley, Diamond and CP they are all very good pistons. If you are going to have someone local build the engine I would get with them and see what brands they prefer to work with, most engine builders have their favorites.
Earl
Old Dec 12, 2012 | 12:02 PM
Old Dec 13, 2012 | 08:19 AM
Originally Posted by cdynaco
I totally agree!!! Jaja good one
Old Dec 14, 2012 | 03:55 PM
I'd start with something like this and build on it..........
http://www.brenspeed.com/b326.html
Sep 8, 2015 10:45 AM
DVSdan
Aug 12, 2015 11:04 AM
Scothew
Jan 24, 2006 06:40 AM
Scothew
Sep 20, 2005 09:02 AM
dallasw77
Jul 30, 2004 04:26 PM
