Here is my 11 Second video.
This was during a bracket class I had to get into to keep running.
I had to let the other guy go first do to the handiacap of bracket racing and also I still run stock suspension wich bounces alot out of the hole as you can see.
Yeah, it looks like you could actually improve alot on the start.. I notice you do have the Predator, so maybe it was just the suspension that looked like a bog down.. Nice run man..
How do you plan on fixing the suspension problem?
http://www.cheperformance.com/cartgenie/pr...p?pid=85&cid=18
Maybe this will help..?
I have the predator and SCT2 wich is the one I was using for this run.Just had it programed on the dyno last thurs with the SCT.
Yes, the hopping action which occured is taking away from your straight line launch energy.. With the Drag pack kit in the link, the wasted torque from the momentary hopping at the launch can be used and not wasted...
The kit should allow you to pull up a front tire, on the drivers side, rather than allow the front end to settle back down and bounce back up..
Being that the car settled down, and you still trapped out below 12 sec, I would say your tune and motor is running really strong.. It actually helped make up the loss of straight line energy at the start of the race. So your all set there...
The kit in the link could most likley get you down to 11.7 ET, if not slightly less.. Maybe 11.5 et..
Originally posted by dustindu4@October 2, 2005, 9:40 AM
Cool video mike! Don't worry bounce is a good thing, it means you're laying down a #$%! load of power.
Yes we know he is making some good power.. I'm just suggesting a way to improve on the overall ET... Visually the bounce shows lots of power.. But theoretically, it shows wasted energy at the other end of the track..
Originally posted by Blazing Saddles@October 2, 2005, 12:12 PM
Nice run Mike. Did you get any shots of my car.
BTW that Drag Pack is not for an 05.
Cdvision
Sep 5, 2015 05:22 PM
