HELP! Need advice on strut and spring removal
![Exclamation](https://themustangsource.com/forums/images/icons/icon4.gif)
I'm wanting to install the Steeda High Performance Upper Strut Mounts.
Does anyone have a PDF for the factory service procedures on how to remove the strut and spring assembly?
and what is the difference between a "correct strut/spring clamping device" and the incorrect “external spring compressors“?
This referenced in the Steeda instructions.....
http://www.steeda.com/directions/555-8120-steeda-strut-mounts.pdf
It doesn't say they're "incorrect" - just that they can be used, but Steeda doesn't recommend them.
The "correct" kind they're referring to are probably something like this:
http://www.etoolcart.com/index.asp?P...OD&ProdID=1497
I used the "not recommended" kind like this and had no problems:
http://www.autobarn.net/cta4035.html
I used those "not recommended" ones and I see why they dont recommend them. They are a little scary. After the first one I did alright though. It feels like the spring is going to slip off sometimes. But I dunno it never happend and im still here!
What springs are you running? With lowering springs I don't use a compressor since the spring doesn't have a whole lot of preload when unloaded. If they're stock springs the simplest and easiest thing to do is take them to a shop and have them swap them on for you. I'll be you can catch someone willing to do it for about $20 near the end of the day or as filler work. The whole process should take about 5 minutes each with the right tools.
I used the "non recommended " ones this past weekend. I got them a few years ago from from Autozone as loaners and just kept (forfieted the deposit). They worked great on the stock set up. Steeda ULs on D-spec didn't require the tool on the install. My tool has the hooks for the spring and a sping loaded pin to completely cover the spring coil. I felt safe using it.
I posted before and after pics in this thread:
http://forums.bradbarnett.net/showpo...8&postcount=24
Indeed. I didn't rent a spring compressor because I didn't think I'd have to compress them much to get them on and I wasn't taking my OEM struts/springs apart. However, when I started the install it was clear that there was no way I was going to get them on without a compressor - and even then I had to crank them down a ton to keep them from contacting the upper strut mount in order to tighten the strut nut.
I purchased new upper strut mounts and spring isolators (probably didn't need them as the steeda springs have a plastic isolator on them already). I had picked up a set of GT takeoff springs from a guy on ebay back when I got the car so I didn't have to cut my stock rear coils - and he shipped the stock dust boots with the springs (a bonus I hadn't counted on). That just left the bumpstops which I picked up from Ground Control suspensions.
Your car looks lowered in your avatar
As for compressors,
I used the clamshell type compressor and it was a pain in the nuts. I was flyin along and the compressor tool was the biggest PITA of the project-as it's near impossible to get it to sit square with the very sharp angle of the springs and very few coils to work with. It took longer to use the compressor then to do the entire rear end. When I do it later to put in d-specs or the like I will use the 'standard' compressors, or do it on a weekday and just bring the struts into work and use the big mamajama tool in the shop that's a piece o cake. I may also go a little more hard core with next set of springs(I got the ultralites as they don't beat up on the stock struts very much) and I can just put the whole strut together first. I passed on the isolators as Steeda doesn't say to use the big rubber ones the factory does and it has their own design on them already. No issues with it at all. From what I understand, the clamshell type is for a straight, normal coil spring anyway and the separate single-bolt type compressors are actually referred to as strut compressors.
With any of the ones you use that are not free-standing, just keep the top of the strut pointed away from you and your feet away from the bottom of the strut and you really can't get hurt if it 'pops' anyway. It only 'jumps' about an inch(unless you quickly cut the bolt or something like that with no compressor)beyond the absolute furthest out you can loosen the cap nut, but with enough force to break fingers or ankle bones easilly.
If it really is only 1/4", are you SURE you clocked the springs so they sit in the groves on the cap and base of the strut? And the cap is supposed to be rotated so the 'half moon' grove in the edge faces out. If you missed the grooves on both ends it would be about 1" off, and would be a ***** to compress it. You can look into the wheel well and clearly see the 'groove' the bottom of the spring should seat in, just turn the wheel and take a peek at the bottom rim of the spring's mount(can't see the top though). There is a visible \_ shape where the coil's pigtail should sit.
I posted before and after pics in this thread - you can see there's very little noticable difference.
The rear looks right, as one coil cut is very close to the steeda drop. It does look the same in the photos. Odd, because mine is def lower then stock and with the factory 18"s(which are virtually identical to the 17"s outer diameter) As of today, I sit at 28 1/16" both sides in the front, after 150 miles to settle them, an alignment, and another 400+ miles
![33](https://themustangsource.com/forums/images/smilies/33.gif)
9/16/15 06:44 PM
robjh22
9/8/15 12:31 PM
