Help me pick my mods for this year
9 is not my lucky number.
Originally posted by Blazing Saddles@December 26, 2005, 11:45 AM
The bigger alternator pulley will slow down the alternator even more. My setup works just fine, thank you.
you want smaller to spin more
If I put 4.10 gears in with M/T tires, am I going to kill my posi? Should I be proactive and put in an Eaton carrier? George didn't you have to replace yours? I don't know anything about these, I just saw you guys talking about it in an old thread Mike started.
Would line locks prevent me from breaking my stock one?
Guest
Posts: n/a
I didn't break my differential, I wore out the clutch packs.
The first thing you need to do is look at your future goals. Do you want to run 10's, 11's 12's. The quicker you want to run the more dough you'll spend.
If I were you I would just start out with the Line Locks. They will take a lot of stress off the clutch packs when doing burnouts.
If you have any problems down the road you can always replace the clutch packs, and add another clutch disc to each side.
I chose to go with an Eaton, main studs, and a girdle, because I knew I was going to be very hard on it.
alright thanks, I'll just get the line locks. I don't see myself going faster than 12.7. The line locks are a good idea anyway.
I'm going to call SLP performance on Monday and see if they plan on making a line lock kit for the 05 like they have for the 99-04. If not I'll get some solenoids and I'll wire and bend the tubing myself (double flare, yes). I may at some point be bugging you to tell me what fittings I need for it. I've never touched the brakes on a car before so it will be a learning experience.
You don't have the Ford service manual DVD by any chance do you? If not I'll buy it and make copies for us NED guys.
Also, here is some info on hooking up two B&M solenoids (w/pics!). http://www.modularfords.com/forums/2005-mu...lock-41137.html
Guest
Posts: n/a
Originally posted by don_w@December 27, 2005, 8:49 PM
Everytime I've contacted SLP, they've told me they have no plans for an 05 kit.
Guest
Posts: n/a
Originally posted by dustindu4@December 27, 2005, 9:42 PM
So what's illegal about it, the solenoids themselves or the just the fittings? If you put good fittings on it they would be good to go?
George... do you have pics of yours?
Guest
Posts: n/a
Originally posted by Blazing Saddles@December 27, 2005, 8:06 PM
No. I'll take a picture of one tomorrow and post it here.
Thanks, George!!
Originally posted by Blazing Saddles@December 27, 2005, 8:26 PM
I looked at the pictures of the B&M solenoids. He's got aluminum compression fittings on the solenoids which are ILLEGAL
here's an interesting switch... wire up the horn
http://www.motorsportsdigest.com/tech/install2.htm
Guest
Posts: n/a
Originally posted by nonsensez9@December 29, 2005, 2:20 AM
newb question... what is a compression fitting and a double flared?
MRGTX
2007-2009 Shelby GT500
1/2/24 04:30 PM
MRGTX
9/8/15 03:19 AM
