Help: Link to a swaybar installation how-to
Old Jun 3, 2010 | 01:45 PM
The Reverend's Avatar
Hey,
TacoBill doesn't have one. Steeda doesn't have one. It seems easy to me, but I am a visual kind of guy that likes pictures. Anyone have a how-to for sway bars?
Thanks.
Old Jun 3, 2010 | 04:53 PM
MTAS's Avatar
Question
Originally Posted by The Reverend
Hey,
Thanks.
Front or rear, which one?
Old Jun 3, 2010 | 05:39 PM
PFCTBLU's Avatar
Hey,
Thanks.
I ordered these Eibachs too. Take a few pics during the install if you see anything out of the norm please.
This vid should help get you going
Old Jun 4, 2010 | 08:54 AM
Sorry, no how-to from me; I'm still running the stock sways.
Here's a couple how-to's I found..
http://www.mustangmonthly.com/howto/.../photo_03.html
(Watts Link) http://www.musclemustangfastfords.co.../photo_04.html
Old Jun 5, 2010 | 03:59 PM
MTAS's Avatar
http://www.stangtv.com/forum/bmr-s19...kage-6271.html
Old Jun 5, 2010 | 05:37 PM
Ministang's Avatar
I installed my Eibach swaybars a couple of weeks ago. Not much to it really. I rarely referenced the included Eibach instructions. I did it on short ramps, took under an hour per end.
Old Jun 6, 2010 | 02:27 PM
R.A.F.A.L.E.'s Avatar
If you need any help or advice, let me know. I installed them myself.
Old Jun 6, 2010 | 02:33 PM
What size mm sockets did you use? Did you use loctite on the bolts?
Old Jun 6, 2010 | 06:11 PM
Ministang's Avatar
I don't remember all the sizes of sockets and wrenches I used, nothing out of the ordinary though, any standard socket/wrench set should have the job covered. The only thing I used loctite on was the allen bolts on the rear bar links.
Old Jun 7, 2010 | 05:30 PM
aircare84's Avatar
14,17& 19mm on the rear bar + allen wrench for the end links.
Cannot remember for the front. I think 14 & 17 or 19 up front as well. The front sway bar links have a real small stud, 6 or 8mm.
Did you get the Eibach directions with your kit?
If not, I can scan & email you mine.
Attached Thumbnails Help: Link to a swaybar installation how-to-dsc04960.jpg
Old Jun 7, 2010 | 07:48 PM
Allen wrench, I am going to have to hunt those down in a box somewhere in the shed. I have the wrenches.
Old Jun 8, 2010 | 10:23 PM
Almost done, gonna need to tighten everything with the tires on the ground.
Old Jun 9, 2010 | 12:04 PM
I had to start all over. I had the sway bar upside down. I talked to eibach and they straighten me out. The other challenge was that I torqued down one of the bracket nuts more than 52 ft lbs, I accidentally left the setting at 85 when I tightened the chassis bolts. I noticed the nut starting to bend a little, so I stopped. Remember to change to torque settings, check! Torquing the nuts on the ground is nearly impossible. I tightened them somewhat tight in the air, then lowered and torqued to 85 and 52 lbs.
I give the front sway bar installation difficulty as a 1 out of 5 and the rear sway bar as a 2.5 out of 5. The time is 40 minutes for the front and 2 hours for the rear, on a first time basis. Otherwise cut the front down to about 20 minutes and the rear to about an hour and 15 minutes.
I needed a 8mm, 14mm, 15mm deep, 18mm, and 19mm sockets and wrenches. I used gear wrenches, a breaker bar, and one 12" extension and were very helpful. Both rear tires needed to be removed, neither front tire needed to be removed. This does work on a convertible with the additional rear-bracing.
Feffman
Sep 28, 2015 06:46 PM
Feffman
Southeast
Sep 24, 2015 05:06 AM
MRGTX
Sep 16, 2015 08:08 AM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
