Hawk Pads: Which one should I get?
Old May 22, 2008 | 08:16 PM
rony1976's Avatar
Ok, so I'm getting ready to purchase drilled/slotted rotorpros with hawk pads. I have the BF Goodrich SS lines on order, I've purchased the Shelby brake duct kit as well as the brake bezel for the GT/CS lower grill.
When it came time to look for the pads, I found there are 3 different models of Hawk pads? Which ones should I get? Ceramic, Plus or Street?
Your input is much appreciated!
Old May 22, 2008 | 09:24 PM
slowjoe24's Avatar
I'm running the HP Street and have been very happy with mine!!
Old May 22, 2008 | 10:06 PM
GRAYPNY's Avatar
+1 on the HPS pads.
Old May 22, 2008 | 10:24 PM
Wardog 07's Avatar
From the Powerstop Website:
It helped me decide.
Ceramic vs Metallic Pads
There are many rumors about ceramic pads causing excessive abrasive wear on the rotors or not holding up at high temperature. I conducted tests on 10 different metallic and ceramic pads to compare performance and wear characteristics.
The products included Hawk, Performance Friction, Raybestos, Power Stop, EBC, Akebono, Morse, and a widely used economy pad from China. There were five ceramic and 5 metallic pads. All data was performed using the test protocol in ISO NWI 2560 on a Chevy Tahoe front axle corner. The tests were run by Link Testing in Detroit. This is an aggressive test that pushes the pad to more than 1200 Fahrenheit, and conducts high speed stops, fade snubs and panic stops. One popular ceramic name brand pad did not make it through the test as it was completely consumed before the test ended. Therefore, I was only able to compare four ceramic and five metallic pads.
I measured and recorded the following:
. Rotor wear
. Pad wear
. Green friction coefficient (mu) - before the burnish or cure on the vehicle
. Fade snub friction coefficient (mu) - 15 consecutive stops without cooling
. Hot stop friction coefficient (mu) - above 1100 Fahrenheit
. Speed sensitivity - the percent change in mu at 160 kph vs 80 kph
. Pre-fade pedal pressure sensitivity - % change in mu
. Post fade pedal pressure sensitivity - % change in mu
Background:
About 25 years ago, we were using asbestos as the binding fiber for the friction compound. It was the ideal product to resist high temperature, and the barbs along the fiber captured various elements and contained it in a nice homogenous mix. When asbestos was phased out in the late 80's and early 90's, compounders had to find a good substitution for asbestos such as iron fibers, chopped kevlar or fiberglass. Development focused on a non-asbestos organic variety and a metallic type pad. That is, until Akebono developed the first ceramic pad. It was a giant leap in brake formulations because it provided outstanding noise, vibration and harshness (NVH) properties with stable mu over a wide temperature range. A true ceramic pad contains no ferrous metal, so there is no metal to metal contact between the pad and the rotor. However, the SAE has no definition of a ceramic pad to specify minimum contents of various elements. So a manufacturer could take a low metallic pad, sprinkle some ceramic stuff in the mix and call it ceramic. This has led to a wide variation in brake performance from brand to brand.
Are ceramic pads bad for your rotor?
Friction works primarily with two mechanisms: 1) abrasion and 2) adherence. Abrasive friction consumes the pad and/or the rotor with a cutting action. Adherent friction is when the pad material is deposited on the rotor, and a friction force is produced from the breaking of chemical bonds as material in this deposition layer is sheared. Abrasive pads will cause higher rotor wear (normally less than .002") and decrease rotor mass. Adherent type pads can actually increase rotor mass. At higher temperatures, adherent friction is the primary mode of producing a friction force.
In analyzing the test results, I found no correlation to make a general claim that ceramic pads are hard on rotors. In fact, it is clear that some metallic pads are more abrasive than some ceramic pads. The pads that were easiest on rotors were Akebono ceramic, Power Stop Z26 metallic and Performance Friction metallic.
Do metallic pads perform better than ceramic?
Under cold conditions, brake torque was not significantly different between ceramic and metallic pads. What I find interesting is what happens as temperature gets up to 1000 degrees. This is where metallic pads have the edge. Ceramic mu tends to drop at extreme conditions.
In summary, the general statement that all ceramic pads are hard on the rotor is false. There are advantages to ceramic pads in terms of uniform pedal pressure characteristics, low noise and low dust. Ceramic pads are a great street compound and can give better performance than some metallic pads. The advantage of metallic pads is improved high temperature performance. I recommend metallic pads for extreme performance such as hauling loads, track racing, towing trucks or traveling in mountains. Our Z36 series has super stopping power even at extreme temperatures. Power Stop offers Evolution ceramic with a nice compromise between pad bite and stability. Of all the products tested, Power Stop Evolution operates close to Akebono (the OE pad) in performance.
Old May 23, 2008 | 05:15 AM
MaverickMLFD371's Avatar
HPS pads....
Old May 23, 2008 | 07:00 AM
EastCoast07GtCs's Avatar
I'm sold on the HPS pads, anyone know the best place to get them... on the cheap???
Old May 23, 2008 | 07:08 AM
TillmanSpeed, thats where I got mine at a good price, I forget what I payed. but I'm sure there are vendors who are having Memorial Day discounts or sales.
Old May 23, 2008 | 07:10 AM
Cool, gonna pull my calipers to re-paint and upgrade to the Steeda SS lines so this is the perfect time for me to get them!
Old May 23, 2008 | 08:42 AM
GRAYPNY's Avatar
FYI, Earl's makes some great SS brake lines and they are probably cheaper than Steeda's.
Old May 23, 2008 | 09:19 AM
slowjoe24's Avatar
I got mine from www.mossmustang.com back when they were on sale. I can't remember the price, but I saved a little bit.
rony1976's Avatar
So either nobody is leaning towards the Plus or nobody has tried them yet?
Are we getting more of the HPS' due to price difference, or truly performance difference?
Old May 23, 2008 | 09:26 AM
slowjoe24's Avatar
Price for me.......but the performance is great so far. I've run them for approx. 5K miles now!
Old May 23, 2008 | 09:33 AM
rony1976's Avatar
If price was not an issue, would you purchase the ceramic ones? If NO, why not?
Old May 23, 2008 | 06:46 PM
Stoenr's Avatar
I already went thru one set of HPS. Great pad if you dont mind the extra dust and some noise when in colder temps, or cold brakes.
I picked up the HP+'s and will put them on next week, but will only be using them for road course events. I hate the dust!
One of our parts supliers (NAPA) is gonna give me some of these new ceramic pads they are carrying. Called Adaptive One. We have been using them on cars at the shop for a few months now with zero comebacks.
So for free pads Im willing to try them. They sound interesting. As interesting as a brake pads can get, lol.
Features & Benefits:Using Two Different Friction Formulas In The Same Set Of Brake Pads Gives Adaptive One The Capability Of Responding To Any Driving Style, Road Or Weather Condition.,Product Features:Adaptive One Is A New Technology In Braking That Combines The Best Of Semi-Met And Ceramic Friction Materials Into One Braking System.,Bonded or Riveted:Integral
http://www.aftermarketnews.com/defau...e=art&id=83456
Old May 23, 2008 | 09:17 PM
Well I stayed away from ceramic because Rich over at RotoPros (the rotors I am using now) suggested they weren't good for the rotors. I almost bought a set of the Centrics he sells, but changed my mind last minute. Not sure if it's the zinc plating, but that was what he told me.
BTW: I too HATE THE DUST!!!!
Old May 23, 2008 | 09:53 PM
STANG_IT's Avatar
I just bought the Hawk HPS pads as well. I paid $123.00 for both front and rear at my wife's work with her staff discount. I'm planning on ordering my front and rear rotors from her work as well and until I get them, my Hawk pads will remain in the garage.
Old May 24, 2008 | 05:11 AM
Hey nice price STANG IT, does your wife's discount apply to your 'cousin EastCoast' too????
Old May 24, 2008 | 09:10 AM
rony1976's Avatar
I found them for $112. If interested, PM me.
Old May 24, 2008 | 09:19 AM
Stoenr's Avatar
Tire rack has a decent price on them, worth a phone call.
Old May 24, 2008 | 09:55 PM
STANG_IT's Avatar
Wow! And I thought I got a good deal !!
