Guage Install Question
Guys need a little help; I had ordered my GT with out the all the optional gauges cause i knew i would install true aftermarket guages later. I just need a little tech help on where the sensors are the the 4.6 motor. For the Water temp , Oil Pressure, and volt . I am used to the 5 lilter motors
thanks in advance
MB
thanks in advance
MB
thanks in advance
MB
thanks in advance
MB
http://www.parts.com/partlocator/index.cfm...005&catalogid=1
It's expensive, but looks like it came that way. If you do this you get the info center and the my color.
The only drawback is that the milage has to be programed in at the dash center. So you will have to leave your car with the dealer for a few days. The dashes are shipped next day or second day.
Check out this thread.
http://forums.bradbarnett.net/index.php?showtopic=15841
Heath, with all due respect, and this has been discussed at length on here before, he's looking for true gauges that actually have numbers and move dynamically as the conditions of the engine change.
MB, for the water temp gauge, there is a bung on the top of the intake right near the thermostat. Almost like Ford knew we'd want a real gauge and made it easy for us! I haven't taken the plug out or anything, but from the looks of it, it's threaded and would accept a sensor for your mechanical or electrical gauge.
For the oil pressure, I'll check next oil change (or someone else can who will be under the front of the car) but there should be a bung near the filter. My 96GT had a bung right near the filter, and the factory "gauge" sensor was in there. I removed the sensor, and threaded in a braided stainless steel line (I had mechanical gauges on the 96). To keep the factory "gauge" from reading 0, I simply grounded the wire.
Good luck and keep us informed. Once Autometer shows us pics of either a pillar pod or a pod to go between the steering wheel and main bezel, I'll be installing electrical water temp and oil pressure gauges as well.
I've attached a pic of where the sensor for the water temp gauge could go.
Originally posted by Montrose@March 10, 2005, 8:16 AM
Thanks. I am looking at doing the same - oil and water gauges. I read in one article that Ford states the 'oil pressure' gauge in the GT is really an 'oil level' gauge - just tells you if there is enough oil in the car, not the pressure.
Originally posted by MTAS@March 10, 2005, 7:52 PM
The factory oil pressure "gauge" is a dummy switch that reads fat dumb and happy with anything above 6psi or so.
And here's a close up. You'd have to install the sensor or braided line while you're changing the oil, because when you unscrew the factory sensor, oil will come out And the factory sensor? Cut the wire and ground it to keep the factory idiot gauge happy.
Diode Dynamics
6/12/18 03:26 PM
