GT500 fuel pumps and foglights
Old Feb 23, 2008 | 10:58 PM
cobra4548's Avatar
Anyone not been able to use their fog lights after installing the GT500 duel fuel pumps? I am having this issue...
Old Feb 23, 2008 | 11:01 PM
theedge67's Avatar
That is a strange problem. Is the engine running? The fogs turn off when the engine is not running, but the regular headlights still work. Battery saving mode I guess.
Old Feb 23, 2008 | 11:07 PM
tom281's Avatar
Uh, sounds strange........ I have the GT500 fuel system here, haven't noticed any problems with anything, let alone the fogs...... ?
Old Feb 24, 2008 | 08:24 AM
tmcolegr's Avatar
Yes!!! Are you using the Saleen or FRPP setup? This is a known issue with the Saleen kit but can easily be overcome. The Saleen kit takes it's power from the foglamps. Therefore after installing, your foglamps no longer work. Thump_rrr found an easy way around this if you have a coupe. Instead of using the foglamp circuit as a power source, you now use the convertible top circuit.
http://www.modularfords.com/forums/s...ad.php?t=60242
Old Feb 24, 2008 | 09:46 AM
cobra4548's Avatar
I am actually using the FRPP setup....:-(
Old Feb 24, 2008 | 10:49 AM
DavidM's Avatar
Does the FRPP kit use this same source for power? It proabably does.
Old Feb 24, 2008 | 11:38 AM
cobra4548's Avatar
Not sure. The car is at the shop so I can't test the turn it on when its running check. I don't think we had the car running when I checked the fogs. It's easy to forget such easy things when you don't drive them for several months.
Old Feb 24, 2008 | 11:47 AM
DavidM's Avatar
Indeed. I'm sure Kurtis will get it all sorted out. I just hope your not paying by the hour.
Old Feb 24, 2008 | 08:26 PM
theedge67's Avatar
I just checked further, and it turns out the fogs will turn on if the key is in the "run" position. They turn off if the key is turned off, but the headlights remain on no matter what.
I thought the engine needed to be running, but I was wrong. Only the key in the "run" or "on" position.
Old Feb 25, 2008 | 07:45 AM
cobra4548's Avatar
We checked and it was just a loose harness. Thanks for all the help everyone.
GLOCKer
Sep 28, 2015 05:20 PM
Sep 16, 2015 06:44 PM
Beouch
Sep 16, 2015 06:14 PM
