GT500 driveline
Old Jun 17, 2007 | 01:27 AM
DynamicmustangGT's Avatar
GT500 driveline
I am going to building a motor this winter and was wondering if anyone knows how much hp and trq a GT500 tranny, and rear end will hold up to and how much the GT will hold up to?
Old Jun 17, 2007 | 01:28 AM
Also wondering if the heads from an 05 GT will fit on a terminator block?
Old Jun 17, 2007 | 08:50 AM
blbrchnk's Avatar
Most say around 450RWHP is the safe point for the GT. Not too sure about the GT500.
Old Jun 17, 2007 | 10:43 AM
jedikd's Avatar
3V vs 4V, so no
Old Jun 17, 2007 | 10:52 AM
Thomas S's Avatar
The GT500 engine will take 800rwhp easy. Not sure about the trans or rearend. I'm pretty sure the GT500 has the same 8.8 as we do. That's probably going to be your weak link.
Old Jun 17, 2007 | 11:36 AM
ov3n's Avatar
Can the GT500 block withstand as much as the Ford GT block?
Old Jun 17, 2007 | 12:58 PM
Thomas S's Avatar
No. But it's plenty strong.
Old Jun 17, 2007 | 03:50 PM
Bullitt995's Avatar
Eh no...
If you're actually talking about the block itself the GT500's would be stronger because it's iron not aluminum. The GT's block has seen 1000+ rwhp so it's plenty strong anyway.
Old Jun 17, 2007 | 04:03 PM
RedDragon777's Avatar
i have seen a Ford GT hold up to 1400RWHP down here in TX and the guy goes to the track at least 3 times a month since he installed the turbos last year and so far no problems
Old Jun 17, 2007 | 05:18 PM
Bullitt995's Avatar
There's only one 1400rwhp TT GT that I'm aware of and it's Joe's in florida. Got any pics? Joe's might be stock block but I'm not sure.
Old Jun 17, 2007 | 05:21 PM
Knight's Avatar
Needs to be more Astony
Originally Posted by jedikd
3V vs 4V, so no
You can bolt any top end 2v 4v 3v to any bottom end. 3v heads would work completely fine with a terminator block.
Old Jun 17, 2007 | 05:43 PM
I was thinking terminator block and reusing my heads. Thanks knight thats what I thought.
Old Jun 17, 2007 | 06:57 PM
Thomas S's Avatar
Originally Posted by Bullitt995
Eh no...
There's a lot more to it than the material used. I'm quite sure the GT's block is stronger than the GT500's. Ford made **** sure:
http://www.roushind.com/news_downloa...04-01-1252.pdf
Old Jun 17, 2007 | 07:11 PM
Bullitt995's Avatar
Very, very interesting read but the GT500 was designed after the GT was. I'm fairly sure they made an almost identical iron block for the GT500. The GT500 uses the EXACT same aluminum heads as the GT.
Old Jun 17, 2007 | 07:13 PM
I have heard about the GT having better internals. If you want to dicuss the 5.4 blocks please start your own threads and stop hijacking.
Old Jun 17, 2007 | 07:17 PM
Thomas S's Avatar
Well since the Ford GT was Ford's supercar/halo/world beater they used the best of the best. I don't know all the specs but I've read that the GT was built much stronger. I'm looking now for the specs on the GT500 engine block.
Old Jun 17, 2007 | 07:52 PM
kevinb120's Avatar
I don't remember there being a question about the block The gt500 rear is the same as the Gt's. The T56 has a dual plate clutch setup IIRC. May want to check svtperformance.com and see what the guys modding GT500's are getting out of the clutches.
Old Jun 18, 2007 | 08:43 AM
TillmanSpeed's Avatar
Former Vendor
I got a Coast Aluminum GT500 Driveshaft in stock!
CR
Tillman Speed
Old Jun 18, 2007 | 12:40 PM
eci's Avatar
eci
Nothing else will bolt up. His entire front accessory drive system including water pump and timing cover will not work.
Dynamic: Keep the Mustang GT block it is plenty strong even past 500RWHP. Buy a terminator crank and rods, and some better pistons. The rotating assembly will work in the s197 GT block.
Old Jun 18, 2007 | 12:43 PM
eci's Avatar
eci
The GT block uses a dry sump oiling system and is very differernt from the GT500 block. It is also much stronger. You can't just say "well it's aluminum and the GT500 iron so it must be stronger."
I guess my 5.0 iron block which will split at 500RWHP is stronger than a GT...
