GT Intake Plenum Cover
Old Oct 5, 2009 | 08:27 AM
Len's Avatar
Len
I can get a good deal on a used 2010 cover for my 2008 GT. It doesn't include hardware. I know the 2005-2006 GT's required studs. Anyone know if the cover will fit my 2008 using the existing hardware from the engine?
Old Oct 6, 2009 | 12:10 PM
Torched05stang's Avatar
According to the our Ford catalog they are the same from 2007 on up.
Old Oct 6, 2009 | 05:38 PM
Len's Avatar
Len
I confirmed it fits but does it use the existing hardware on the intake? I think the 2005-2006 required studs.
Old Oct 8, 2009 | 08:00 AM
825LTRGT's Avatar
If you have the studs on the TB, you need 5MMx1.5 nuts (if I remember), a washer, and they fit fine. I posted the pitch before the crash and I think it was 1.5 but don't know for sure.
If you have an '08/'09 the studs should be there.
Old Oct 8, 2009 | 09:48 AM
The Ford catalog picture show the 6MM studs are the same also for 2007-up. and it uses a 5mm nut.
BUT when I ordered mine(cover) from Ford it came with bolts not studs. So I now see why you've asked the question. Good luck.
Old Oct 8, 2009 | 10:13 AM
partsbill's Avatar
2005 to 06/05/06 the upper throttle body had bolts at the top, from 06/05/06 they replaced them with studs, you will need 2 studs ford part# W712289-S437 to replace the bolts, careful to not over tighten the studs, shop manual shows
Torque Specifications
TB stud bolts 10nm / 89 lb-in
Old Oct 8, 2009 | 11:12 AM
He has a 2008 so they should already be studs from the factory....Right??
Old Oct 8, 2009 | 11:30 AM
partsbill's Avatar
I didn't catch that, yes anything after 06/05/06 should have the studs.
Old Oct 8, 2009 | 11:41 AM
Len,
The short of it is..If you already have the studs(factory installed) for the top two locations of the TB then all you need is the two 5mm nuts. Part number W520411.S437 from Ford
Old Oct 8, 2009 | 05:59 PM
825LTRGT's Avatar
Get the nuts from Ford for $2 ea or go to the hardware store and buy 2 - 5mmX1.5 pirch nuts (1.5, I think) and two washers for .49.
Old Oct 9, 2009 | 07:16 AM
+1
but some may want to have the factory stuff.
Old Oct 9, 2009 | 11:28 AM
Len's Avatar
Len
+1
I'm not that ****....yet! Thanks to all for the help.
Old Oct 9, 2009 | 11:33 AM
Len's Avatar
Len
Thanks for the info. What are "pirch" nuts or is that a typo?
Old Oct 9, 2009 | 01:04 PM
he meant "pitch"
Old Oct 9, 2009 | 11:26 PM
825LTRGT's Avatar
Yup..typo.
5mm x 1.5 pitch
Old Oct 10, 2009 | 06:48 AM
topbliss's Avatar
I put on a factory plenum and my 07 did have studs already on it., The 08 should too
RoushRS3
Sep 29, 2015 08:03 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
