Ghost Cam Tunes
I know all about the 5.0 ghost cams, whole reason 3V don't have them is do to Ford unofficially asking tuner company's not to make those tunes any more do to the plans they had in the future for them Boss's and the Boss key technology. There is only one post about them on you tube from a kid in Puerto Rico. So I was just asking if any body had info on like what they do, pro and con. Thanks again.
Ghost cam tunes were for 5.0 only. The only benefit was sound, which is subjective. Seemed like I've heard a lot more people that had issues with it, than people that were happy with it.
My limited understanding of the ghost tunes in the 5.0's is that the tune is possible because it is a dohc motor and the lobe cam separation can be changed. This is not possible with the sohc 3v.
The 3v has VCT, it just has one cam per head so it's not possible to add overlap for the cam lope.
There is no such thing as a ghost cam tune for a 3v, if you saw it anywhere it was a joke. I'm guilty of making such videos after I got my hot rod cams installed lol
Check out the video in you tube, just look up 06 GT ghost cam. Look for the sct tuner and you'll know your there.
He probably has aftermarket Camshafts and is pulling people's legs.
No way is valve overlap possible on a SOHC engine. You have to degree the intake and exhaust cams to overlap the valves to get "Cam Lope", which you can't since there isn't separate intake and exhaust cams like on a DOHC motor.
Just ask yourself, if it were possible, don't you think aftermarket tuners would offer a cam lope tune for the 3V 4.6? They would have nothing to lose, and only money to gain.
I assume you mean this video? Video Link: http://youtu.be/UFCHwmTgZ7w
I'm almost 100% sure he pulled a vacuum line at this point. Take a look at this video, the owner has a vacuum leak which is causing the lopey idle.
I just watched a few vacuum leak videos of 3V mustangs and they all have some type of choppy idle. You could pull a vacuum line to recreate a cammed sound, but I don't recommend it.
There is a ghost cam option for the V6... a friend here has ordered it from MPT-Performance".
It does sound great, however I can just imagine that it can't be good on the long-run...?
http://www.morepowertuning.com/ghostcamtuneform
