Gears or Driveshaft?
Old Apr 12, 2007 | 10:16 PM
bad_monkeys's Avatar
I have heard great things about both mods, but was wondering which is the better choice?
Old Apr 12, 2007 | 10:25 PM
Knight's Avatar
Needs to be more Astony
gears will give you the best gain... but doing both would be the best!
Old Apr 12, 2007 | 11:03 PM
official_style's Avatar
both
Old Apr 13, 2007 | 05:05 AM
scramblr's Avatar
Both...If you can't do them at once, go with gears first, will give you the fastest SOP difference.
Old Apr 13, 2007 | 07:33 AM
281GT's Avatar
If you can't afford both at once do the gears first then the drive shaft.
Old Apr 13, 2007 | 08:34 AM
Believe me I would love to do both, but can only afford one or the other right now. I was just curious which would result in the greatest acceleration gain. Thanks for the help.
Old Apr 13, 2007 | 09:07 AM
freebass55's Avatar
I would do gears first.
Old Apr 13, 2007 | 10:43 AM
eci's Avatar
eci
gears.
Old Apr 13, 2007 | 03:57 PM
tom281's Avatar
Gears...... since you're comparing gears to a driveshaft, I'm assuming you've factored the labor to install the gears too.
Old Apr 13, 2007 | 04:01 PM
Well that’s it. They will both run roughly the same price so I was looking for the best result. I have never been in a Mustang with a deeper gear so I don’t know what to expect.
Old Apr 13, 2007 | 04:09 PM
tom281's Avatar
Def do the gears...... remember this: unless you do HUGE amounts of hiway driving, DON'T FEAR THE GEAR! 4.10s with a manual trans is great; 373s for an auto is great.
Old Apr 13, 2007 | 04:13 PM
05-1947's Avatar
+1 ^ Gears!!!
Old Apr 13, 2007 | 06:06 PM
RobK's Avatar
GEARS!!!
Old Apr 13, 2007 | 09:40 PM
TillmanSpeed's Avatar
Former Vendor
Here is the deal.. factor in atleast 300 for install on the gears. (PLEASE! By a reputable shop and NOT your backyard job because the gears WILL whine and you WILL not like them. Additionally, make sure they use the friction modifier, it's worth bringing it to a shop that charges you 350 over Bobs Truck and Tire saturday morning gear special for $199.99 with free tire rotation and perm.)
Which is more affordable right now after that included?
Gears, install kit, royal purple oil, we sell for 275-300 depending on what ratio. With 300 dollars it will put you between $575-600.
Oddly enough, our Coast Aluminum Driveshafts run $589.99 shipped to the door, and can be installed by the typical do-it-yourselfer.
It's a tough battle, especially being identically priced... we push our driveshafts we sell hard, and even I agree... I'd love to sell you a driveshaft, but the gears make the driveshaft effects worthwhile.
Go with the gears. Immediately there-after when funds are available... go for the driveshaft!
CR
Tillman Speed
610-497-3711
P.S. Tom281 nailed it... DONT FEAR THE GEAR. 410s for manual, 373s for automatic.
Old Apr 14, 2007 | 11:00 AM
mrkabc's Avatar
Thinking about this myself... my question is:
Does the 4:10 gear make first gear pretty much unusable? ("granny gear"?)
Old Apr 14, 2007 | 01:19 PM
302svt's Avatar
Gears first then save for the drive shaft. Maybe the price will come down by then.
Old Apr 14, 2007 | 03:00 PM
GRAYPNY's Avatar
NO! You will love 4:10's and 5th gear is only a couple hundred rpms more at 70 so you aren't going to take a huge hit on gas mileage. Your gas mileage will suffer at first though because you will have a hard time keeping from matting it all the time and you will also notice that your rear tire wear isn't as good as it was before the gear swap!
Old Apr 14, 2007 | 03:08 PM
goldenpony's Avatar
Choice
My God-get the gears! Any improvment with a drive shaft is all in a persons mind, "I spent a ton for this driveshaft-it has to make my car faster".
Old Apr 14, 2007 | 04:53 PM
shatter's Avatar
I believe it was posted elsewhere that in 5th gear, 4.10 rear becomes an effective 2.79 rear end ratio. My 69 has 2.79 gears and that is a great ratio for the highway. Based on that info alone, I have been thinking of doing FRPP 4.10 gears but then I don't drive my car all that much either but 4.10 gears are a blast in Rich's car.
Old Apr 15, 2007 | 03:48 AM
mrkabc's Avatar
Well, I think you have talked me in to a set of 4:10s!
Now I need to find a reputable installer, like CR says above...
