gears
Old May 16, 2007 | 11:31 AM
jmanpatsfan's Avatar
gears
are there any set of gears that would enable you stay in first gear longer. it seems that i have to shift out of first so quickly and if im sitting at a light then it turns green, i cant get ahead of anyone, even minivans are beating me off the line. Also, is it dangersous to constantly bring the revs up to 4 before shifting?
Old May 16, 2007 | 12:32 PM
neil07gt's Avatar
Installing a lower rear gear (i.e. 3.90, or 4.10) for better acceleration will lower your top speed in each gear, thereby shortening your "stay" in each gear. You'll get a great launches but your upshifts will come sooner. You can't exactly have it both ways. You can mitigate the time wasted during a shift by installing a short throw shifter.
Old May 16, 2007 | 02:04 PM
don_w's Avatar
Or go with the 4.10s, and start in 2nd gear. You'll be able to beat most minivans that way.
Old May 16, 2007 | 03:36 PM
SlamMan02's Avatar
Im confused...Im sure its an exaggeration but how would a longer first gear help you beat a minivan off the line? Maybe your shifts are too slow?
Typically to help get a car off the line you want a lower gear (higher numerically ie: 390s, 410s) So you can get the revs up faster and get to the powerband quicker.
Old May 16, 2007 | 06:23 PM
RadBOSS's Avatar
Because he is suggesting using second like first by using higher numerical ratio diff. Not sure that is a good solution. 1st is shorter than ever and 2nd starts off like a standard Mustang. What does that accomplish.
For flat land driving, 2nd gear starts are not that hard on the clutch. It just won't accellerate as lively.
This is not a close ratio trans. 1st gear is nearly a granny gear or a real stump puller, so its over pretty quick. Only way to get more out of 1st is with a lower numerical gear in the diff (automatic diff), or get a close ratio trans (don't belive this trans is available from TREMEC with close ratio gearing). The lower gear ratio diff solution however will have a negative overall effect on the car getting to speed, unless you are going out for land speed attempt.
Old May 16, 2007 | 10:35 PM
281GT's Avatar
This is incorrect. You can beat most minivans starting in 3rd with 4.10's.
What does this prove? Well not much except that maybe I'm a bigger smart@$$ than you!!!
HA!!! TAKE THAT!!!!
Rando
Aug 25, 2021 11:12 AM
AMAlexLazarus
Oct 15, 2015 11:06 PM
Rando
Sep 30, 2015 12:28 PM
Airborne42
Sep 24, 2015 10:27 AM
