gear tune
gear tune
Do you need to re-tune with new gears. Also, what would the best gear ratio and how much will I be looking at for an install. thank's
speedo will be off so you need a tune to correct it but there is no affect on shiftpoints if you have a manual. just shift at whatever RPM you normally do. you coulddrive the car for the rest of your life without a retune if you wanted to. jsut gotta rememebr your speedo is off.
Rando
8/25/21 11:12 AM
