gear tune
Old Oct 2, 2006 | 11:54 AM
SONICBOOST's Avatar
gear tune
Do you need to re-tune with new gears. Also, what would the best gear ratio and how much will I be looking at for an install. thank's
Old Oct 2, 2006 | 12:45 PM
94tbird's Avatar
i paid 450 for the gears plus the install with new gear oil, friction modifier, and a new bearing. i got 4.10s. great set of gears
Old Oct 2, 2006 | 01:20 PM
traffic142's Avatar
I got a set of FRPP 4.10's and if you got the tune from doug, email him and he will mod the tune for you and send it back to you.
Old Oct 2, 2006 | 03:44 PM
SONICBOOST's Avatar
Do you have to re-tune with the new gears?
Old Oct 2, 2006 | 06:50 PM
OKLACOP's Avatar
Yes.........Your speedo will be way off and your shift points will change.
Old Oct 2, 2006 | 06:52 PM
94tbird's Avatar
speedo will be off so you need a tune to correct it but there is no affect on shiftpoints if you have a manual. just shift at whatever RPM you normally do. you coulddrive the car for the rest of your life without a retune if you wanted to. jsut gotta rememebr your speedo is off.
Old Oct 2, 2006 | 07:54 PM
SONICBOOST's Avatar
Thank's, by speedo i'm guessing you mean speedometer
Old Oct 2, 2006 | 08:02 PM
GRAYPNY's Avatar
If you don't recalibrate after you swap gears you will put alot of miles on your car very quickly.
Old Oct 2, 2006 | 08:08 PM
SONICBOOST's Avatar
All I would need is the tuner to recalibrate right.
Old Oct 2, 2006 | 08:15 PM
GRAYPNY's Avatar
I believe you can do it with the SCT Xcal II. I had to send mine back to Doug since I have the Xcal 1 version.
Old Oct 2, 2006 | 08:16 PM
94tbird's Avatar
correct
Rando
Aug 25, 2021 11:12 AM
Bryanh24
Oct 14, 2015 08:43 AM
Sep 30, 2015 07:02 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
