Gear Heads Only
Old Apr 2, 2005 | 09:00 AM
mikem's Avatar
263-15882, 2.5" Magnaflow 05 Axle-Back 263-15882 $438.64 $438.64
555-3120, Cold Air Kit for 05 Mustang 555-3120 $259.95 $259.95
146-ST7140, Predator for Steeda Modified 05 Mustang GT 146-ST7140 $399.95 $399.95
555-3305, Underdrive Pulley System 555-3305 $249.95 $249.95
Sub Total $1,348.49
Ok I'me about to order this list, but one item in question is the Underdrive Pulley.My car has the shaker 1000 system and I am wondering if running the underdrive pulleys is going to affect my voltage?I do notice with stereo base pounding lights do dim slightly with each big base hit.Also with all the new sufisticated electronics the car has i am wondering that the drop in voltage might affect Fuel pump,Spark,and all the other things that need full power.When i was racing GrandNational,s I remember people having battery problems with underdrive pullies.
Old Apr 2, 2005 | 09:28 AM
S197 GT's Avatar
3rd Times A Charm
Sub Total $1,348.49
Not neccesarily realted...but, you should check out crossroadzdirect.com for your MagnaFlows. They've got the Axle Back set for 399.95
Old Apr 2, 2005 | 09:54 AM
2005RedGT's Avatar
I have had the Steeda UD PUllies for a few months. I also have the Shaker 1000 and use it quite often. I have had NO issues.
Go for it
-Bryan
Old Apr 2, 2005 | 10:44 AM
bullittman's Avatar
I have had no issues either, on the Steeda underdive pulleys
Old Apr 2, 2005 | 03:05 PM
tmcolegr's Avatar
Are you aware you can purchase the C&L CAI & Predator bundled together from RPM Outlet for $629.95? I personally have the C&L CAI and Predator.
http://www.rpmoutlet.com/05gt.htm
Steeda underdrive pulleys from Part Shopper for $180.45. Use coupon code "stangnet"
http://www.partshopper.com/fordmustang/ite...tatus=0&Tp=&Bc=
Magnaflow Axle-Back exhaust from Part Shopper $397.62. Use coupon code "GM2565".
http://www.partshopper.com/fordmustang/ite...2D15882&eq=&Tp=
Let's see that's $140.47 less than you quoted. I'll split the difference with you.
PS: I am not cheap - just very thrifty!!
Old Apr 3, 2005 | 01:10 PM
dhof303's Avatar
Sean Hyland Motorsports pullies are exact duplicates of the Steeda part and cost $169.00 instead of $249.00. They are a quality SFI product that performs great.
Rando
Aug 25, 2021 11:12 AM
NC14GT
Sep 10, 2017 04:47 PM
Sep 30, 2015 07:02 PM
earl610
Sep 7, 2015 11:57 AM
