future plans
future plans
its an '06 auto GT: So far I have a BBK intake, UPR off road x pipe, and Magnaflow cat-back exhaust. Still don't have a tuner
....but that is what this thread is for! I plan on getting a BBK 62mm throttle body, Steeda underdrive pulleys, and a FRPP intake manifold sometime soon. So, who should I get the tuner from (of course with the tune already)?? Also, is there anything else that I should get along with this stuff? I know I know....gears....hmmmm
If you plan on adding more parts then I'd get an sct tuner an unlimited tune files from bamachips through American muscle. This will let you retune anytime you add a new mod and bama tunes are some of the best mail order tunes available.
Also, unless you're planning on getting heads and cams or going fi then I wouldn't waste my money on a new manifold.
no, these are all of the mods i'd ever do to the engine. so the manifold isn't worth it or what? i thought it would make decent power without cams and heads
Well bama will provide you with free tunes with the tuner. Some other companies will do the same but most charge extra for the tunes.
As far as the manifold if you aren't adding cams or heads I wouldn't bother with it. For the price it isn't worth it. Only 10 maybe 15 horsepower.
For the same price you can add some gears (3.73 or 4.10) or maybe some suspension parts to keep the power on the ground.
