Fuel System Outline
Old Nov 15, 2008 | 03:06 PM
classix_stang289's Avatar
Fuel System Outline
Can anybody provide me with a diagram of the fuel system? I need to do some diagnosis of the
fuel system and it would really help me if anyone can point me in the right direction for a diagram
thanks guys
Old Nov 15, 2008 | 03:16 PM
anybody?
Old Nov 15, 2008 | 06:08 PM
Got Oatz's Avatar
See if these will help you out.....
http://www.2005stang.com/gallery/alb...el%20lines.pdf
http://www.2005stang.com/gallery/alb...uel%20tank.pdf
Old Nov 15, 2008 | 08:00 PM
thanks buddy that helps a ton, by the way do you know if i have to drop the fuel tank to get the fuel pump out or can i access it by taking the rear seat out
Old Nov 15, 2008 | 10:44 PM
my06gt's Avatar
You can get the pump out by removing the back seat it is under the drivers side of the back seat
Old Nov 16, 2008 | 12:43 AM
jaguarking11's Avatar
is it just me or does the fuel tank have two sending units and tanks?
Looks weird.
Old Nov 16, 2008 | 03:13 PM
whats happening is i think my car is choking on fuel and when i let the car sit a long time then go to start it up, it will run fine for 2minutes then run like garbage for about a minute then clear up. when this happens there is a reallllllllllllllllly strong gas odor. It trips a oxygen sensor stuck rich code, but theres nothing wrong with my sensors and something is making it get stuck rich. I dont know where to start diagnosing so i figure i try to start with the fuel system like something as far as, leaking injectors into the cylinders, fuel pump as far as pressure or just plain old faulty, plugs,coils,anything fuel related that is making my car run like garbage
it all started happening after i installed my OBX LT headers. i know the sensors are further back but i put new ones in to try and fix it and it didnt work. my tuning it from brenspeed and i tried receiving different tunes to try and fix it but that didnt work either. this was a once in a blue moon problem that is now a every day thing.
Maybe its cause of the headers and i need different headers so the sensors are closer to the engine?
can anybody give any suggestions? please? ask other people that you know as well?
Sep 24, 2015 08:15 PM
Sep 16, 2015 06:44 PM
Sep 10, 2015 12:44 PM
