FRRP Stinger Install
Old Sep 26, 2006 | 05:51 PM
one_mean_marine's Avatar
Just got my ford racing performance stingers in from lethal performance for my 06 GT and ran into a problem. Got the pipe on and hangars bolted up but i cannot get the tips to line up with the cutouts in the bumper i cannot see any way of getting the hangars to toruque enough to get the tips lined up with the notches in the bumper for the tips. Any help or suggestions would be greatly appreciated or my last bet is to show up at the ford dealer with the factory mufflers off and new pipes in the trunk when i pull up into the service bay which i don't think would be a good idea on my part!! LOL
Old Sep 26, 2006 | 06:09 PM
sts767's Avatar
seems like I read in another thread to loosen the clamps upstream on the pipes and adjust from there and hopefully you can get the right alignment. I guess I was lucky mine lined up right out of the box.
Old Sep 27, 2006 | 06:50 AM
SteelTownStang's Avatar
Yeah, what is said... loosen the mid-pipe connections. There are numerous threads/posts on this... You can also go to various mufflers's sites(Corsas, Flows, etc.) that will provide instructions as well. I, however, found it easier to just slightly bend the the hanger bar on the muffler itself. Fit was perfect.
Old Sep 27, 2006 | 12:28 PM
06stalliongt's Avatar
is there anyway u can get a sound clip of the new mufflers, i've seen alot of people talking about them so i guess they must be pretty good
Old Sep 27, 2006 | 12:38 PM
Here ya go. video clip
It's a comparison between STOCK - FRPP/BORLA STINGERS - (adding) PYPES O/R H-PIPE.
Old Sep 27, 2006 | 08:34 PM
Boltzman's Avatar
I too slightly bent hanger bar by puttin it in my vice.Mine line up perfectly now..I will admit ,a simple 45 min to 1 hr job ended up taking me about 6 hrs with all the readjusting. It was a PITA
Old Sep 27, 2006 | 08:37 PM
steevr's Avatar
Bill,
I like the sound of the stingers even with the cats. When you had this setup (before the off road pipe), did you have any problems with the stingers droning??
Thanks.
Old Sep 27, 2006 | 08:58 PM
Ya should've went straight to the mid-pipe clamps for the tip adjustments, would've saved you about 5 hours and 15 minutes.
j/k Boltz, glad you got it 'straightened' out, if you ever swap out the axle-backs again, you know what to do.
Originally Posted by steevr
Bill, I like the sound of the stingers even with the cats. When you had this setup (before the off road pipe), did you have any problems with the stingers droning??
The Stingers will drone between (roughly) 1700 to 1950 rpm's (cruising 55 to almost 70 mph). You'll know you're in the Drone Zone when your ear wax begins to loosen.
You and you passengers will quickly realize that this ain't no stock set-up!
Old Sep 28, 2006 | 08:32 PM
Fords4Ever's Avatar
I was originally thinking SLP Loudmouth but that clip really has me leaning toward the FRPP Stingers and probably the FRPP X-Pipe.
Does anyone have a vid comparing SLP LMs and FRPP Stingers? Are the LMs alot louder than the FRPPs?
Old Sep 28, 2006 | 08:45 PM
Remember what I mentioned here about the Stingers...
Here's an entertaining clip on the SLP LM's up on YouTube.
BTW- the LM's are louder than the Stingers, but not by much. There is a tone difference too, Stingers being lower.
14Glassback
Oct 4, 2015 08:52 AM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
