FRPP springs + Maximum Motorsports PHR =
Read here:
http://forums.bradbarnett.net/showpo...18&postcount=1
http://img.photobucket.com/albums/v6...l/IMG_7295.jpg
Note: Tight wound coil going up into the body, loose wound coil toward axle. Steeda directions does not address spring orientation. I called Steeda Tech Support to validate correct position. Also, there's no mention on which way to orientate the coil pigtail ends, I just positioned the Steeda coil ends where the OEM ones were.
