FRPP Handling pack and Camber Adjustment?
i plan on installing the FRPP handling kit on thursday. do i need a camber adjustment kit for this or should i be fine?
I had one side in and the other side out. If I remember correctly, the struts came w/the bolts for setting camber. But it's been awhile and I could be wrong.
But you should have it checked any way because at a minimum, the toe will be off.
The camber isn't that far off with an approx. 1.5" drop. Plus, the camber change results in toe-out making the steering quicker.
I would only restore the camber if tirewear was a major concern for you.
I had this kit installed and even after grinding out the holes on the front struts per the application instructions from Ford Racing:
http://www.fordracingparts.com/downl...tM-18000-A.pdf
I have about 1.75 degrees of negative camber on the left and 1.5 degrees on the right. At this point I am going to leave it alone and keep an eye on tire wear. If tire wear becomes a problem then I will get the camber adjusted back neutral.
Love the FRPP pack. Improved handling on the track and the car looks great with the lowered stance. Street ride is definitely quite a bit firmer but by no means intolerable, and no scraping over speedbumps, etc so far.
BTW here is a link to some pictures my mechanic took during the install:
http://www.pbase.com/frodaddi/install
Kevin.
Kevin.
