FRPP/Eibach Sway Bar settings
I was just wondering what setting you guys are running with this setup? I've got mine setup in the middle for the street, which seems to be fairly neutral. I might adjust mine to add a bit of understeer for the street.
Right now mine is set for street as well. Feels better then the stock setup. I'll probably try the other settings soon. Let me know what you think if you switch it up.
I still need to adjust my pinion angle and install my Steeda LCA relocation brackets. I've noticed that I get a bit of oversteer when the pavement is damp. Adjusting the front sway will help, but I like how the car is currently setup.
