FRPP 3.73 gears
Old May 10, 2008 | 09:18 AM
08gt's Avatar
Smile FRPP 3.73 gears
Hey guys,
Can anyone tell me if the FRPP 3.73 (8.8) gears from Here are the "A" ford part and not the "M" part?
Does anyone know if there is a better price out there, and is a "shim kit" needed if buying a new set of gears?
Thanks!
-Steven
Old May 10, 2008 | 02:04 PM
crucut's Avatar
I don't know for sure, I'd call and ask, but I do know they have a seperate gear set available labeled "motive performance gears" so maybe the Ford racing ones are the "A" that your looking for.
Old May 10, 2008 | 05:04 PM
edumacate me please ...whats the difference?
Old May 10, 2008 | 05:17 PM
gmantheman's Avatar
The ones that end with "A" are Ford Racing. The ones that end with "M" are motive. I believe that Ford also makes motive, but the motive gears tend to whine. I believe it is because they are harder than the normal Ford racing gears.
Old May 10, 2008 | 11:01 PM
07GTTOM's Avatar
i know the whole "A" vs "M" issue is true with the 4.10 gears, i have never read about it with the 3.73 gears...
Old May 11, 2008 | 07:50 AM
08gt's Avatar
Bump,
Anyone got an answer on the second part of my question?
Old May 11, 2008 | 07:58 AM
xtoolmaker's Avatar
Be safe and buy the Ford Racing gears not the Motive.Just got my 4.10's installed no whine.Good price and delivery from Blue Oval Industries.com $155.00 for the 3.73 gears,
Old May 11, 2008 | 08:13 AM
xtoolmaker's Avatar
You should not need anything other than the parts that come with the gear set other than a couple of quarts of gear oil .I used Royal Purple which has the friction modifier in it. Amsoil is also recommened. I had my gears installed down here in Orlando by Jake Lamotta at his race shop they or any good shop will have anything needed to do the install.I did add the new low profile rear axle girdle from Ford racing adds a little extra support if you plan on racing.
Old May 11, 2008 | 01:40 PM
08gt's Avatar
Ok, so "Ford Racing M-4210-B 8.8" Ring & Pinion install kit" are not needed? Everything that is needed comes with the gears in the box? I just want to make sure so I can get it all orderd at the same time. I'm going to go with the Royal Purple gear oil as well. Thanks for the help!
-Steven
Old May 12, 2008 | 10:53 AM
08gt's Avatar
Well this is totally frustrating. I can not find a shop around here for less then 750 to install the gears. I went ahead and bought them from BOI, was a great price. At this rate I'm tempted to just try and do it myself.... which will probably end up in disaster but I am not going to spend 750+ to just have some gears installed.
Old May 12, 2008 | 11:22 AM
08gt's Avatar
I think you are right about that. I was assuming it was for all gear sets, but it looks like it was just an issue with the 4.10s. Thanks for clearing that up!
Old May 12, 2008 | 11:38 AM
GOarmy08's Avatar
Let me know how your install goes... lol. I need to get some 3:73s rockin' on my 08, also.
Old May 12, 2008 | 12:40 PM
08gt's Avatar
w00t! I found place out of Lubbock that will do it for 275+oils. I have to drive the car 120 miles to take it there but heck for that price I'm in like Flynn. IF anyone in the West/North Texas area needs s197 or any mustang work for that matter, go to Protech in Lubbock. These guys are bad ***.
-Steven
Old May 12, 2008 | 03:02 PM
07GTTOM's Avatar
-Steven
might want to reserve that quote till after the install, if everything goes well. They are so far away, make sure everything is good to go before you drive back home, make sure those gears dont wine. Do a search on proper gear break in procedures.
Old May 12, 2008 | 04:31 PM
TillmanSpeed's Avatar
Former Vendor
Tillman Speed Light Em' Up packages include "a" gears only with FRPP Genuine install kits and Royal Purple oils!
CR
Old May 12, 2008 | 08:41 PM
delz05's Avatar
Tillman...how much for 3.73's shipped to 02190? Send a pm please with payment info as well. Thank you!
Old May 13, 2008 | 03:55 AM
mvon919's Avatar
You might want to go with new -F373N, these are totally new design and are much better than A's and especially Motive (M) gears...
"New manufacturing technology utilizing a Face Hob Process which features a single pass pinion tooth machining operation compared to a conventional three pass process for machining. CNC cut and lapped gear teeth. Higher strength and better quality gears are produced with the Face Hob Process. NOTE: These new gears look a little different, the gear teeth are cut on a different angle and the ring gear has a bevel on the back of the gear."
Old May 13, 2008 | 08:47 AM
fazerxx's Avatar
Hey Chris, I'd like to know some info on this also, shipped to 56201 zip.
Thanks!!
Old May 13, 2008 | 02:56 PM
08gt's Avatar
Awesome, good to know! Thanks!
-Steven
Old May 14, 2008 | 09:57 AM
Former Vendor
3.73's are $264.99 shipped to the door for the 3.73 A's, Royal Purple 75w140 (3), and Installation kit. We're also putting together a package for $319.99 shipped to the door for the FULL installation kit (pinion and carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, pinion gear, carrier bearings and cover gasket), F373N Gears, and Royal Purple 75w140 (3).
