Front spring install help!?!
Old 12/28/07 | 05:38 PM
Pwny's Avatar
I just got my BMR front springs in today, but I'm stuck on the installation.
There is this bracket on the lower strut that connects the strut to the spindle. Its an L shapped bracket that gets in the way and WILL NOT allow us to remove the bolts.
I wish I could attach pictures, but I can't get my camera to work.
Tacobill's how to thread did not mention such a bracket.
Thanks.
Old 12/28/07 | 06:09 PM
hammeron's Avatar
sorry i can't be much help....all i can
offer, is the service manual procedure
which you may already have
File Type: pdf
Old 12/28/07 | 06:45 PM
91svtcoupe's Avatar
best i
best I remember that just acts like a brace to keep the bolt from turning you just need to go from the other side and turn it and you don't have to hold a wrench on it. Just go from the other side.
Old 12/28/07 | 06:52 PM
DavidM's Avatar
Are you referring to the nut with stop sleve from the factory on the strut to spindle bolts (2X)? I can't think of any other "L" shaped items under there.
Old 12/28/07 | 07:00 PM
06GT4RAD's Avatar
Yep I am with you two guys that is all I can figure it to be as well.
Old 12/28/07 | 11:02 PM
Pwny's Avatar
We got it taken care of! Thanks for the help guys.
Old 12/29/07 | 03:11 AM
bob's Avatar
bob
Did you make sure the springs and upper strut bearing where "clocked" correctly.
Also did you replace or use loctite and correctly torque the various bolts and nuts used. They are torque to yield items (used extensively in the suspension)?
I've got a post listing the various ft/lbs and Nm specs for most of the bolts and nuts.
<--edit-->
Torque specs for front Suspension
(Nm = Newton Meters ft/lbs = Foot Pounds in/lbs. = Inch pounds)
Brake Caliper Bracket Bolts: 133 Nm - 98 ft/lbs.
Dust Sheild Bolts: 20 Nm - 15 ft/lbs.
Wheel Spindle Pinch Nut: 103 Nm - 76 ft/lbs.
Lower Control Arm Bolt (front): 175 Nm - 129 ft/lbs.
Lower Control Arm Bolt (Rear): 175 Nm - 129 ft/lbs.
Heat Shield Bolts: 10 Nm - 89 in/lbs.
Brake Line Bracket Bolt: 20 Nm - 15 ft/lbs.
Strut Upper Mount: 62 Nm - 46 ft/lbs.
Strut to Spindle Bolts: 200 Nm - 148 ft/lbs.
Strut to Body Nuts: 35 Nm - 26 ft/lbs.
Wheel Hub Retainer Nut: 300 Nm - 221 ft/lbs.
Stabilizer Bar Bracket Nuts: 70 Nm - 52 ft/lbs.
Anti-lock Brake Sensor Bolt: 6 Nm - 53 in/lbs.
Outer Tie-Rod Ends: 80 Nm - 59 ft/lbs.
Steering Gear Mounting Bolts: 115 Nm - 85 ft/lbs.
Torque Specs for Rear Suspension
(Nm = Newton meters ft/lbs. = Foot Pounds in/lbs. = Inch Pounds)
Rear Shock Absorber Upper Nut: 40 Nm - 10 ft/lbs.
Rear Shock Absorber Lower Bolt: 115 Nm - 85 ft/lbs.
Lower Arm to Body Bolt: 175 Nm - 129 ft/lbs.
Lower Arm to Axle Bolt: 175 Nm - 129 ft/lbs.
Panhard Rod to Body Mount Bolt: 175 Nm - 129 ft/lbs.
Pahhard Rod to Axle Bolt: 175 Nm - 129 ft/lbs.
Lateral Stiffener Bar to Body Nut: 115 Nm - 85 ft/lbs.
Lateral Stiffener Bar to Body Bolts: 62 Nm - 46 ft/lbs.
Stabilzer Bar Bracket Nuts: 70 Nm - 52 ft/lbs.
Stabilizer Bar Link bolts: 115 Nm - 85 ft/lbs.
Parking Brake Cable Bracket to Lower Arm: 27 Nm - 20 ft/lbs.
Upper Control Arm Front Bolt: 175 Nm - 129 ft/lbs.
Upper Control Arm Rear Bolts: 115 Nm - 85 ft/lbs.
Upper Control arm Bushing Nut: 175 Nm - 129 ft/lbs.
Fuel Tank Strap Bolt: 51 Nm -38 ft/lbs.
Brake House Bracket Bolt: 20 Nm - 15 ft/lbs.
HizliBullet
GT350
14
11/14/15 08:59 AM
SMBJoshy
8/24/15 10:55 AM
DarrenGT
8/21/15 07:07 PM
RocStar69
8/21/15 07:33 AM
Quick Reply: Front spring install help!?!
