Front Force 10 8-Piston Aluminum Caliper Disc Brake Kit
Old Oct 19, 2006 | 03:31 PM
06GTwJUICE's Avatar
Has anyone installed this kit yet and if so, how do you like it?
I made my choice as far as rims to go on my car (18x9 Bullets in front and 18x10's in back) in december and this brake kit seems like a good choice for the front.
I wanted to know if anyone has gotten it yet?
EDIT ***** Specs of kit *****
Ford - Mustang - (2005 - 2007)
Disc brake kit with Force 10 V8 8-Piston Aluminum calipers and 14" rotors.
General Specs:
Part NumberA112-17
Retail Price$2,495.00
Minimum Wheel Size18"
Axle Front
Interested in this kit? Send us an e-mail. Caliper Specs:
NameForce 10 V8
Number of Pistons8
Piston Size35mm
Constructed FromAluminum
Standard FinishClear Anodized
Optional FinishesPolished or Powder Coated
Rotor Specs:
Diameter14"
Thickness1.250"
VentingDirectional (curved vane)
Standard FinishSlotted and Plated
Optional FinishesNone
Bolt Pattern5 x 4.5"
Old Oct 19, 2006 | 07:08 PM
Cali HP addict's Avatar
Lightbulb
If that is your cup of tea. I think they are way overkill and have a downside of adding un necessary weight.
Old Oct 19, 2006 | 07:15 PM
DarkHorse305's Avatar
MM&FF had an article on the install of the kit. If i remember right, they only fit with 20in rims.
Old Oct 19, 2006 | 08:02 PM
06GTwJUICE's Avatar
Their website says minimum size 18" rims... but I'll do some research, it's possible that they don't even though they say it does...
any suggestions for a 4 or 6 piston caliper....
I dont mind a little overkill.... I'm only going to buy the kit once...
Old Oct 19, 2006 | 08:08 PM
06GTwJUICE's Avatar
General Specs:
Part NumberA112-17
Axle Front
NameForce 10 V8
Number of Pistons8
Piston Size35mm
Rotor Specs:
Diameter14"
Thickness1.250"
KIT FEATURESAll hardware included.Bolts to stock spindles.Calipers come with clear anodized finish. Optional polishing or powder-coating available.Includes Force 10 V8 8-Piston aluminum calipers.Includes high performance pads.Includes Turbo slotted rotors with Xtra Life plating.
Click here to see the caliper's standard clear anodized finish. Click here for wheel fitment diagram. To order your calipers with optional powder coating, add the appropriate suffix to the kit number when ordering. (For example: kit A100 with blue powder coated calipers would be A100BU; kit A100-1 with red powder coated calipers would be A100-1R.)
BlueBlackYellowOrangeBUBKYO
RedSilverPolishedRSPO
Old Oct 19, 2006 | 08:13 PM
http://www.livermoreperformance.com/...e_kits.html#st
Here are some other options.
Old Oct 19, 2006 | 09:46 PM
wsmatau's Avatar
Stop-Tech 4 piston kit is the best performer for the money IMHO.
Old Oct 20, 2006 | 04:06 PM
StillenMustang07's Avatar
Authorized Advertiser
A 4 piston Stoptech will run about $2400-$2500 with all the options. I will finally have my 4 piston AP Racing kit out next week and it will run $2195 with all the bells and whistles (zinc, slots, cross-drilled, two piece 14.25” rotor, etc).
If you have your heart set on SSBC you might want to see if they have a wheel template. I know that our 6 piston front kit will not fit an OE wheel. Good Luck!
Brian
800-858-0534
www.stillen.com
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
lowblustang00
Sep 5, 2015 12:18 PM
DarrenGT
Aug 21, 2015 07:07 PM
AMWill
Jul 20, 2015 08:40 AM
