front end problems
Old Apr 16, 2011 | 08:42 AM
DPHC13's Avatar
front end problems
I had the lower control arms replaced by the dealer on my 2008 GT about 6K ago. Now the front tires are worn on the inside tread. My question is would they have done a front end alignment after the install?
Old Apr 16, 2011 | 08:46 AM
Enfynet's Avatar
Depends on the business. Any suspension work should be followed by an alignment.
Old Apr 16, 2011 | 08:54 AM
05stangkc's Avatar
They Should have. Check your Service order. It should Detail any work Done.
KC
Old Apr 16, 2011 | 09:03 AM
DPHC13's Avatar
the work was done at the dealer. I checked the work order and nothing is said about an alignment. When I made the appointment they said an alignment was done but would not show up on my ticket. Now the mechanic checked the car and said no alignment was done or needed at that time. I thought this was odd. I thought after you take the suspension apart you always did an alignment. Now my car is out of warrantee so I have to pay for an alignment and new tires. It just sucks because i never had a tire wear problem before the LCA's were installed.
Old Apr 16, 2011 | 09:25 AM
05stangkc's Avatar
The only way to really know if a car needs an alignment is to check it.
KC
File Type: pdf
Old Apr 16, 2011 | 10:03 AM
DPHC13's Avatar
well, the dealer is doing an alignment as i type this. I just always feel like i'm getting screwed. Oh well.
Old Apr 16, 2011 | 10:05 AM
Gtpony325's Avatar
Yiu cant help but feel like you are getting screwed while you are at a dealership.
Old Apr 16, 2011 | 12:34 PM
DPHC13's Avatar
Welp! It's done and i'm 60 dollars lighter. They said the toe was out of wack (they used more technical terms). They also pointed out that my sub-frame is new? So the used car that I thought was wreck free was infact in a wreck. On a good note he said it all looks good under the car. I have never seen a "Carfax" that shows the car was in a wreck. I saw the Carfax and it was clean... so i guess they didn't report it? Anyway the front tire are quieter after the alignment. Thats a good thing.
Old Apr 16, 2011 | 01:59 PM
Enfynet's Avatar
I hit a curb and had to replace my subframe. I'd hardly call it a wreck, it just kinked really easily. However, even THAT requires an alignment...
Old Apr 16, 2011 | 06:04 PM
karman's Avatar
Post
Welp! It's done and i'm 60 dollars lighter. They said the toe was out of wack (they used more technical terms). They also pointed out that my sub-frame is new? So the used car that I thought was wreck free was in fact in a wreck. On a good note he said it all looks good under the car. I have never seen a "Carfax" that shows the car was in a wreck. I saw the Carfax and it was clean... so i guess they didn't report it? Anyway the front tire are quieter after the alignment. Thats a good thing.
Carfax is a good tool but it may not show everything.
If somebody replaces a sub-frame in their own garage it will not show up.
Old Apr 17, 2011 | 03:19 PM
DPHC13's Avatar
Thanks for the info guys. She is still a sweeeet ride!
Diode Dynamics
Jun 12, 2018 03:26 PM
RRRoamer
Jan 19, 2017 05:27 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
Mackitude
Aug 17, 2015 04:14 PM
