Flowmasters with ARH LT's and X or H-Pipe
Old Apr 29, 2007 | 09:03 PM
mustangfan123's Avatar
Hi guys, I was on a different forum today,and someone had JBA LT's,JBA Catted H-Pipe,and Flowmasters. I asked him if it sounds deep and he said at 1/2 throttle, when accelerating, and at WOT it sounds deep. But at low RPM cruising speeds he said it had unbearable drone. If I got ARH LT's with an Catted X or H-Pipe and put it on with my Flowmasters, would this unbearable drone at low-rpm cruising speeds happen too, or is it something to do with the JBA LT's or JBA H-pipe's design causing this?
Well, maybe the design of the headers or mid-pipe caused the low rpm cruising drone for him. I am thinking that may be the case since a Prochamber O/R H-Pipe sounds different than a Pypes O/R H-Pipe.
Old Apr 30, 2007 | 12:22 AM
281GT's Avatar
I don't think there would any difference in sound between the JBA or the ARH long tubes. H-pipes and X-pipes sound a little different but the drone you are concerned about is mostly caused by the mufflers. The drone with the Flow masters is probably exagerated by the long tubes but I think any long tube headers would have about the same effect. The removal of the stock cats which is neccesary with the instalation of LTs' is a factor here as well as the factory cats are more restrictive than aftermarket ones therefore they tend to quet things down a little also.
Basically if you don't like drone and you plan to run LT's you probably shouldn't get Flowmasters and look at other choices that are out there.
Sep 24, 2015 08:15 PM
drmag
Sep 1, 2015 03:47 PM
unnoticedtrails
V6 Performance Mods
20
Aug 18, 2015 03:11 PM
SpeedCostsMoney
Ecoboost
Jul 20, 2015 12:47 PM
AMWill
Jul 16, 2015 04:26 PM
