Finished with Mods *FOR NOW*
First off that is well put together....props man
second that molded guage pod is calling my name....where might one acquire one of dem der?
Third, WTF are those 3 switches below the HU??? all3 n2o?
http://www.classicdesignconcepts.com...splay/628.html
here is the link for the hood scoop.
I modified mine alittle bit by cutting out the"nostril" to make it look meaner.
They supply 2 decals fot it but i cut them out.
remove negative battery terminal. remove gauge cluster bezel by pulling off. remove center cluster, pull radio out a little... open glove box -> push it's sides to let it drop down. remove 2 bolts holding airbag assy. unplug airbag wire connector. remove airbag assy. remove bolts and center vent section... cut hole with holesaw (measure twice). cut plastic between vents behind vent covers to make room for your gauges. good luck.
