Factory Specs for Camber
Old Mar 28, 2008 | 09:55 AM
Knightblade's Avatar
Anyone know what the camber setting is on our Cars from factory?
Old Mar 28, 2008 | 05:40 PM
MooStang05gt's Avatar
According to the print out from when I had my alignment after I lowered my car, the factory specs are:
Camber -0.2* to -1.0*
Toe 0.05* to 0.20*
Cross Camber -0.04* to 0.04*
Total Toe 0.10* to 0.40*
Hope this helps.
Bobby M.
Old Mar 28, 2008 | 05:46 PM
My info..
Factory tolerance: -.75 degrees (+/- .75 degrees) which is 0.0 to -1.5 degrees
Old Mar 28, 2008 | 06:32 PM
Stoenr's Avatar
I did not print out my alignment sheet, and I should have, grrr.
It has the min/max listed.
But I do have a pic of where I set it at.
Went on the - high side on camber, for a tad better handling on the road course.
Old Mar 29, 2008 | 11:53 PM
f1-cobra's Avatar
Here's the specs:
Factory Alignment Specifications
Front caster left & right 7.1° ± 0.50°
Total/split 0°± 0.70°
Front camber left & right -0.75°± 0.50°
Front toe
Total/split 0.10 ± 0.20°
Factory General Specifications
Front ride height 38 mm ± 8 mm (1.5 in ± 0.3 in)
Rear ride height 115 mm ± 8 mm (4.5 in ± 0.3 in)
Vehicle lean (side to side difference)
Front & rear-maximum 13 mm (0.5 in)
Dogtracking
Maximum 13 mm (0.5 in)
Clear vision (negative value is counterclockwise) 0°± 3°
Ball joint end play
Lower ball joint-maximum 0.8 mm (1/32 in)
Old Mar 31, 2008 | 05:55 AM
Thanks for the info guys!
Road_Runner
Sep 2, 2024 04:46 PM
RCooke08GT
Feb 19, 2017 03:03 AM
Feb 10, 2017 07:12 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Fred_Garvin
Sep 17, 2015 04:10 PM
