A/F ratio how does it effect H/P and Torque.
Old May 22, 2006 | 03:00 PM
Eleanor Dreaming's Avatar
When I had my car Dynoed it leaned out to 14.2 - 14.3 at the exhaust. Brent has added some more fuel to the tune. Brent wants the A/F to be around 13.5 at the exhaust. I have not put it back on the Dyno and Brent's next Dyno Day isn't until July. Anyone have any idea how that might effect the numbers. Just Curious.
Old May 22, 2006 | 03:34 PM
don_w's Avatar
Lean conditions usually result in increased HP numbers, but that comes at a potential cost.
Old May 22, 2006 | 03:46 PM
tom281's Avatar
Hey Ben, how are you doing? Adding fuel to your may lower your numbers slightly, but likely you'll be better off in the long run. My numbers were 13 to 13.5 at the exhaust just FYI.
You've got a great car. I would trust that Brent knows what's best for your car and add the fuel, even if your numbers drop slightly.
Thanks,
Tom
Old May 23, 2006 | 04:20 PM
Bullitt995's Avatar
To a point.
Old May 23, 2006 | 05:49 PM
dustindu4's Avatar
9 is not my lucky number.
I wish I could have Brent tune my car, that would be awesome. you guys are lucky
Old May 23, 2006 | 06:12 PM
tom281's Avatar
Brent is awesome. With just the mods that I have listed below and his newest tune for the '06 cars, I got 296/316 on his dyno during the dyno day. And the throttle response is killer!
Old May 23, 2006 | 06:25 PM
dustindu4's Avatar
Trouble is with getting a canned tune from Brenspeed and Bamachips, the tunes are never quite right because all cars are different. All my tunes had sucky A/F ratios. Your local dyno place cannot edit the tunes in your tuner, they need special master files that places like Bamachips won't give out because it contains all their secrets.
The only way to maximize the benefits of your canned tunes are to get your cars dynoed and sent your datalogs and dyno graphs to your tuner. Might take several trips.
That's just the nature of the beast, there's no substitute for a custom tune
Old May 23, 2006 | 08:18 PM
traffic142's Avatar
That is what I am looking at to do. Each car is different. I was surprised that the DTP tune was running so lean.
And as for me, the upgrade the Sct 2 stuff and all, I am so lost on that.
Old May 24, 2006 | 12:15 PM
nonsensez9's Avatar
is a dyno necessary? can't you just hook up some O2 sensors and rev the crap out of it in neutral?
Old May 24, 2006 | 02:26 PM
traffic142's Avatar
I think the load has to be on the engine (ie: spinning drive shafts and stuff).
Old May 25, 2006 | 10:01 AM
RRRoamer's Avatar
Per converstation with Doug, once I get my wideband O2 installed I will make several "pulls" in 2nd and 3rd gear and send the data to him so he can fine tune my tune. My problem is that I live at over 5000 feet up, so I am definitely running rich at or near WOT.
But I knew that would be the case going in and discussed it with Doug up front. Now I just need to get off my butt and get the bung installed so I can wire up my LC-1!
Old May 25, 2006 | 12:35 PM
stoon aucoin's Avatar
Tom- what kind of dyno does your tuner tech. use- dyno jet, mustang dyno or other? thanks!
mark0006
Sep 8, 2023 09:46 AM
CiniZter
25
Apr 28, 2016 05:41 PM
Sep 8, 2015 10:45 AM
SilverBullet13
Aug 13, 2015 09:11 AM
Ecoboost
Jul 25, 2015 06:32 PM
