Error Code(P0506) - please help - Idle Control System RPM Lower Than Expected
Old Aug 29, 2006 | 07:07 AM
Dubl10's Avatar
Hello, my car is throwing a CEL again. It's a new error code, which is:
P0506 Idle Control System RPM Lower Than Expected
How can this be fixed, can a tune adjustment be done to fix this or what? Is this something that my tune isn't handling right?
I have an 05 Mustang GT, automatic transmission.
My mods are:
TBS - throttle body spacer
Steeda CAI w/ a Tune, 90mm
SLP Loudmouth exhaust
Kooks Long tube headers w/ catted x-pipe.
In that order of when I put things on.
Now someone mentioned this to me, let me know what everyone else's thoughts are:
I was getting the same code and tried everything to rule out the CIA or the filter the first dealer tried to blame the Code on. Took the car to a different Dealer and they replaced the Throtle Body , under warrenty, becuz it houses the Idle Control part. Been driving the car for two weeks no codes , so far.
Just remember to remove your CIA , if possible, becuz they will try to blame the problem or say VOID Warrenty due to your MODS.
Hey, I had the same problem and the Dealer replaced the Idle Control sensor , which meant replacing the entire throtle body. Just thought I tell you.
Good Luck.
Is that something I'm going to have to do? instead of just correcting this in a tune? I hope i odn't have to replace my throttle body, that would suck, plus, i don't know if I can get that under warranty, with all my mods, I mean, I do know i'll have to take out my CAI, but i don't want to do that.
anyway, does anybody know for sure what needs to be done? just a simple tune adjustment or replacing the idle control sensor?
Should I just take it to the dealership and have them look at it, even with my mods on?
Old Aug 31, 2006 | 10:28 AM
deepblue's Avatar
Exclamation
hi there
i'm Giampaolo from Italy and i have the saem problem to mine GT 05 Autom.trans.
Usually with Air cond in but 2 times also without.
so if you know where could be the problem please help me.
i have set the engine by
Predatoe 93 oct
Steeda Cai 90 mm
Am.Thunder Mufflers
Honestly i think the problem should be the TUNE because 'Bone stock ' this trouble it doesn'e exist
ciao Giampaolo
Old Sep 1, 2006 | 07:40 AM
Dubl10's Avatar
that's what i'm thinking also. I think it's in my tune too. I could go get it dyno'd, but i don't feel like spending 450 bucks to do that when I bought my own tuner, you know. If i find out anything i'll let you know.
Old Sep 1, 2006 | 08:33 AM
deepblue's Avatar
ok thank you in advance. ciao G.
Old Sep 12, 2006 | 11:25 PM
Zeio's Avatar
I had the exact same code and it was fixed when I changed my tune to Bamachips 91 torque. No problems now, and I was experiencing the same thing, with or without AC, gone now and i'm happy.
Old Sep 13, 2006 | 07:11 AM
Rash's Avatar
Why don't you just flash the tune back to stock and see if you still get the code? If you don't, then it's the tune. If you do, then it's not.
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
Ecostang
Nov 3, 2022 08:50 PM
TonyJestis
Aug 21, 2015 06:06 PM
cloyd65
Jul 30, 2015 08:48 AM
