electric water pump?
Yes there are electric water pumps but honestly you only need it for boosted and f/I setups. The factory water pump provides a great water flow for what it is designed to do. Unless you are running boosted applications you won't benefit from having one.
A MEZIERE electric water pump has an idler pulley so you still use the OE belt and route it the same. ![Heh](https://themustangsource.com/forums/images/smilies/heh.gif)
http://www.brenspeed.com/wp346s.html
Originally Posted by nicu7
I want to say muscle mustangs picked up around 10hp with one of these on a supercharged s197
Originally Posted by Glenn
you will still free up a few hp on a non supercharged engine.
Originally Posted by Pete07GT
But with nominal gain at a steep price it would be more beneficial to put the money toward something better for more grip or acceleration. What's the weight on one of these? Potentially lighter than stock?
Originally Posted by cdynaco
Right. I think all these little tricks (underdrive pulleys, alum shaft, etc.) are best suited for a guy that wants to stay NA. If you're going supercharged, why bother.
how much do they cost? The nice thing about the is you can run it even while the car is turned off. like at the track to help the engine cool off a little more than it normally would.
Received 1,556 Likes
Deysha, that link does not seem to work?
From what I hear this is a pretty good low cost mod, frees up about 10 HP and improves MPG, not bad for $200-300
