Eibach swaybar question
Old Nov 30, 2005 | 10:52 PM
creggleton's Avatar
I have almost finished installing my eibach pro-kit and sway bars on my 06 GT Vert. I have a question about the rear bar. After I mounted it, I noticed that it is slightly shifted to the right. (There are no indentations for the position of the bushing on the rear sway bar) I was thinking no problem, I'll just loosen everything and move it left. However, if I move it to the left, one of the bends on the bar will be contacting the panhard rod cover. Should I just leave it where it is? Any adverse effects from not being centered? Thanks for the input!
Old Dec 17, 2005 | 05:40 PM
stkdidy's Avatar
if its close enough to center i dont think there will be an issue, as long as its not going to pop out of place. i did not encounter this problem on mine.
when you took off the stock one, did you make sure that the new one wasn't being put in upside-down? i know i had to step back and think about it for the front cuz it fits both ways. the bend in the middle of the back one go down or up? i think its sposed to go down if i remember my installation correctly
MustangConvert11
Sep 30, 2015 08:01 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
