Eibach Pro-alignment Kit
Old 12/20/05, 07:04 PM
06Tungstang's Avatar
Sure thing Rony, I have a week off from work between Christmas and New Years and plan on doing it then. I'll try to remember to take pics during the install and post them up.
Old 12/28/05, 08:19 AM
rony1976's Avatar
Don't forget to take pics Matt! I'm doing my install this coming Monday, so my pics are coming...
Old 12/28/05, 08:21 AM
I'll try not to. According to Fed-Ex tracking my bolts should be here tomorrow afternoon. Now just to figure out my other dilemma with springs I'll be ready for the install.
Old 12/28/05, 12:07 PM
Bloody Guts's Avatar
maybe I misread the posts, but are any of you guys installing the bolts yourselves?
I dropped my car a few months ago, just got my bolts in the mail
I didn't think there was anyway for someone at home to check the camber without just guessing...
I think I will probably wait till spring, i'll have my new wheels and tires and one winter's worth of sliding around and springs seating
let me know how they work out for you
thanks guys
j
Old 12/28/05, 12:20 PM
rony1976's Avatar
We are not going to adjust the camber ourselves, but the bolts will be there when we take it to the shop to get it aligned. I'm dropping mine on Monday, I hope I get an idea before then as to where the aligning bolts are suposed to go...
Old 12/30/05, 02:06 PM
rjuice's Avatar
uh ok your front struts have 2 bolts on the bottom of them, where it mounts to the spindle. The camber bolts replace the top bolt.
Old 12/31/05, 09:39 PM
Jollygreen's Avatar
Are most of you guys installing the springs yourselves or having a shop do it? Should FORD do it?
Old 1/2/06, 08:23 AM
Jollygreen : Installing my own springs.
Rony: Ended up not needing the bolts, only had a little toe out that needed ajustment.
Since I cut convertible springs, the results were a little different, but I love the feel& look.
The front is only 11/16" lower, while the rear is 1 3/8" lower.
Stock front was 28 5/16" and rear was 29 3/8"
Front now sits at 27 5/8" and rear at 28"
People that have cut stock coupe springs were around 27 9/16" FR and 27 1/2" rear.
Old 1/3/06, 08:19 AM
rony1976's Avatar
Ford would do it if you purchase the Ford Springs from FFRP, but they won't do your aftermarket springs.. that would be voiding the warranty of the car (unless you know someone, they I guess they could do it).
By the way, the car looks GOOD! I have pics, I'll post tonight (hopefully). I'll have some Before and After shots.
Happy New Year everyone!
Old 1/5/06, 10:40 AM
rony1976's Avatar
I found what I was looking for! Check it out... this is where the Eibach Alingment Bolt goes...
http://www.specprod.com/PROD_DIR/C_PROD_pa....txt&cmd2=81260
Enjoy!
Old 1/5/06, 11:03 AM
Retired Tms Staff
adrenalin's Avatar
Enjoy!
Looks exactly like the FORD camber bolts that were installed on my car.
Old 1/6/06, 07:26 AM
rony1976's Avatar
Did that fix the camber problem after you dropped it? I thought I read in your install that it did... I'm going to put it in this Sunday...
Old 1/6/06, 09:39 AM
Retired Tms Staff
adrenalin's Avatar
Yup, fixed it and have had no issues with alignment since.
Old 1/6/06, 09:46 AM
rony1976's Avatar
Awesome, that's what I wanted to hear!
Old 1/19/06, 02:57 AM
StangRalle's Avatar
Stupid question: I bought the Eibach Pro-Kit in Miami/FL and brought it back home to Switzerland.
I will get the springs installed Feb 4.
Now reading all the above, do you believe I should order these alignment bolts? If so I'd have to order them quickly!
Is this really necessary? When I bought it from the performance shop, they did not mention anything. If they wouldn't know, who would? I mean, they are professionals in tuning cars.
What might happen if I install them withoug the alignment bolts?
Your input would be highly appreciated.
Thanks, Ralph
Old 1/19/06, 06:45 AM
rony1976's Avatar
What will happen is uneven tire wear, and also, you won't be able to align it back to stock without the alingment bolts. I did alingment yesterday, if it wasn't for the bolt, they would've not been able to adjust it.
Get the part number from this thread, and just do a quick lookup in the web, I paid like $20 for mine, and I heard that they cheaper through Summit Racing (a different brand, not Eibach's).
Good luck!
Old 1/19/06, 09:54 AM
Redfire 05Gt's Avatar
Driving several hundred km's on them with excessive camber isn't going to wear them out or ruin them. I put about 20,000 km on mine with -1.75 camber before I got the bolts. I can see the accelerated wear on the inner edges. Probably 1 or 2/32" more than the center and outer edges.
As for the "professionals in tuning cars", they probably assumed that you maybe you knew about or wanted the extra negative camber to improve performance in cornering. Or maybe they didn't give it a second thought. Some performance enthusiasts knowingly choose to go that route at the expense of tire wear. Every time I see a lowered vehicle now with wheels slanted in at the top, I wonder if they know what they're doing to their tires! They can corner like a car-on-rails but rubber ain't cheap!
Old 1/19/06, 10:09 AM
StangRalle's Avatar
Thanks, do I need 4 or just 2 alignment bolts?
Just for the front wheels or also for the rear?
Thanks.
Old 1/19/06, 01:32 PM
rony1976's Avatar
the rear doesn't have any alingment components. You only need 2 for the front (upper factory bolt needs to be removed and replace with Eibach's new bolt).
Old 1/19/06, 01:36 PM
  #40
StangRalle's Avatar
pffffffffffffff... thanks... already ordered, but just 2 which were just right.
Thanks!
Quick Reply: Eibach Pro-alignment Kit
