Educate me on CAIs and MAFs
Bill ! I was strictly referring to the other post, in which Bob was referring to the stock exhaust as an airflow restriction, and from a performance point of view only ! Therefore, I didn't miss anything, being that sound wasn't brought up in his post, to begin with..However on the other hand I definitely agree with you, as to why most people do upgrade lol. In fact I've just recently upgraded to Pypes Violators, because of the stock axle backs sounding way too quiet..Although, if just running the Violators still isn't loud enough ? then you can be assured, that my next mod will be an off road H-pipe, or Mac off road prochamber
1. First of all, it's not the MAF itself that's restrictive ! it's the stock airbox which is restrictive, by choking off airflow to the throttle body..
2. And second ! it's been proven on the dyno, by Brenspeed, Alternative Auto, and Anderson Ford Motorsport, that the stock exhaust along with the exhaust manifolds, are considered as factory high-flow components, and are very low restrictive when compared with the previous SN-95 model..As a matter of fact ! there's very little to be gained, by swapping out the stock mainfolds in favor of shorty headers ? as they've only been proven to provide a 2-4 HP gain..In addition, according to Brenspeed's test results ! their off road H-pipe, provided no more than 8-10 peak HP, over the stock mid pipe w/cats..The only real benefit, in swapping out the factory exhaust ? would be in favor of Long Tube headers, along with either an off road or high-flow catted mid pipe..Other than that ! you're pretty much wasting both your time, and money IMHO
1. Now, I can't say that my approach has been super scientific, but I've yet to find the stock airbox restrictive. It's opening is MUCH larger than ther MAF (in the high 90's to 100 mm range compared to the 80 mm of the MAF) and I've yet to find any increase in ET's by doing any kind of change to the box (i.e. remove the filter, remove the lid, remove the whole box), which to me, HAS to indiciate that it's flowing better than the most restrictive part of the intake, which has to be the MAF or the intake pipe. Since the intake pipe only adds like 5 or 8 hp on the Steeda CAI (which is the only intake I have seen that can use the stock intake pipe), that basically rules out the everything but the MAF. The second benefit of the larger MAF is that you can meter more air with introducing less turbulence into the intake path.
2. I agree 100% on the exhaust being high flowing, except for one part. The exhaust manifold... While it may flow on a bench as well as the rest of the exhaust, a flow bench will not simulate the pulses and pressure waves that an actual header/manifold goes thru, nor will it show any kind of scavenging capabilities. Now, I understand your point about the shorties, and agree 105%. They don't make power on the Mods, however, shorties are historically known for not making good power, simply because of the resonance and scavenging tuning that you can't do with them. There is just not enough length in them to pull it off. Long tubes however, can be tuned for both of these things and regularly are. I suspect (and have yet to find it in writing, but I really think its the case) that it's this very scavenging tuning that gives the long tubes their additional Horsepower, above and beyond what the shorties/manifolds give. I also think that the reason this gain from scavenging is so substantial, is that it overcomes some of the limitations designed into the stock heads/cam (which are incredibly well matched to what the rest of the car desires) to keep HP levels and durability well within what Ford considers safe.
The other reason I list it as the 2nd biggest restriction is simply, it's the second largest HP gain you are going to get from a car without forced induction or opening the engine case up. CAI/tune being the first, most guys are reporting in the 20 hp range from what I have seen. And beleive me.. with the bet I have with my brother, I am tracking gains on peoples mods like it's my job.. lol.
And Lastly, Bill, your car is the reason I have a Torch red 07 GT sitting in my garage right now You've made my marriage worse, and my drive to work SO much better..LOL!
Thanks guys. Just started posting over here, tho I am a regular on Mustangforums for a while. I work on the side as a tuner so I have a pretty good grasp on how this stuff works, but am just now moving over from the LSx world into the Ford mod motors 2nd Ford I have owned, and this stang blows away every one of the 14 F-bodies I have had. Anyway, if ya don't mind.. I've picked a couple of pieces apart above that I am going to pick at a bit if ya don't mind (in the name of friendly conversation/debate)... Keep in mind also, my initial reply was somewhat simplified, just so I didn't loose anyone in it, especially the OP who has no background in this stuff.
Being calibrated for a smaller tube the ECM interprets the lower velocity as less air and therefore commands less fuel to the injectors causing the car to run lean.
C&l Mass Air
Gonna pull the trigger on getting the C&L mass air. Anyone have any input on this system. C&L will also provide the 93 oct tune for the preditor for me if I buy through them.
Hey Tony ! The C&L racer intake is an excellent choice..However, you would be much better off, if you purchase both the intake and tuner from either Bamachips or Brenspeed as their custom e-mail tunes, will give you much better throttle response, by getting rid of that nasty throttle lag and also provide better overall performance, over the Predator's canned tunes as well..That being said ! you definitely won't be disappointed
Thanks Bob!
Welcome to the car vs wife club!
Be sure to post up your pic here in the TR section.
And Rocky, lighten up a bit, I know you get pretty passionate in your posts, but try not to scare the new guy away (just yet)!
Most people seem to agree that their car runs better with a CAI and a tune. But it seems to me that the tune is responsible for most of that performance gain. However, do the CAIs have a larger MAF than stock? Is this also a part of the performance gain. I can't see how just the conical air filter alone is responsible for the gain.
Also, if I modify my stock air box to flow more air, am I going to get a CEL if I start running too lean?
If you modify your stock box, it will skew the air transfer function (which is what the tune changes to account for more air going in with aftermarket CAIs). It's best to get the car dynotuned rather than depend on a canned tune.
My opinion is to stick with stock unless you are trying to squeeze every bit of hp to win at the track. The aftermarket CAIs aren't tested as well as the OEM airbox and intake assembly. The OEM spends more money than what these CAI vendors are worth, just to evaluate the airboxes (NVH, thermal, water jet spray, etc...)
Hey, Powerball is up to 161 million. If I win I can buy a dyno shop and play around for a year or so. (Wish me luck. If I win everybody gets free pulls for life)
Actually, I'm not modding the stock air box except to remove the rubber snorkel. All I'm doing is providing a path for cooler air to reach the airbox. I know I'll still need a dyno tune because of the "different" air going into the airbox. I'll probably get a 'Bama or Bren tune, then drive the car to Kansas City and get it dyno'd.
I already said that (NVH).
The OEM intakes are superior because they are designed to handle a variety of conditions. A conical filter might work well for a limited number of applications, but superior filtration and durability isn't one of them. I have yet to see any type of K&N-style oiled cotton gauze filters used in Iraq. I trust the OEM a lot more than I trust some of the aftermarket vendors that depend on customers/beta testers with deep wallets. Saleen's HID kit is a good example of this.
If I remember right, K&N claims a 93% effectiveness on their filtering ability. AEM claims a 99% effectiveness on their dry filter. I don't know what percentage the OEM filter is, but I would suspect it would be very close to 100%. The factory doesn't want to pay any more warranty claims than they have to. I'd give up a little bit of flow and a horsepower or two to have the better filtering capacity.
I've "been there, done that" with nickel and dime mods and other more expensive mods.
When you run an aftermarket intake assembly upstream of the MAF sensor, you will NEED to get a tune, just like when you install a Marauder airbox and MAF on a non-Marauder Panther.
The airbox itself ! has nothing to do with the air transfer function..As long as the MAF housing remains the same size as stock ? the air transfer function remains the same, therefore NO re-tuning is necessary..Case in point ! C&L street intake w/no tune insert along with the Airaid/Roush CAI
Seems to me that would be saying the minute an air filter gets even the slightest bit dirty the A/F ratios will be totally messed up.
#40
Exactly what do you mean, by modify Upstream of the MAF ? are you referring to before the MAF housing or after ? my understand is ! as long as the MAF itself, remains the same size as stock ? it doesn't matter how large the intake tube is afterwards, the air transfer function remains the same..However ! if it does not ? then explain how the Airaid/Roush and C&L intakes with their no tune inserts, don't require any additional tuning. As not only are their airboxes modified ! but are really nothing more, than just heat shields
