driveshaft options
Old Sep 9, 2006 | 02:10 AM
nonsensez9's Avatar
driveshaft options
what are some driveshaft options in addition to the Powerhouse aluminum and BMR carbon fiber?
Old Sep 9, 2006 | 08:11 AM
BuzzyStang05's Avatar
Other than those, all that I know of is the Ranger drive shaft mod described on Modular Fords. I don't know about you, but I'm hoping that rumors of a Ford Racing driveshaft come true.
Old Sep 9, 2006 | 08:44 AM
05BlackGT's Avatar
I've been looking myself. Also found this one:http://www.driveshaftshop.com/item168735.ctlg
Old Sep 12, 2006 | 10:33 AM
Redfire 05Gt's Avatar
That one is a 3" 23 lb steel shaft.
Old Sep 12, 2006 | 10:51 AM
Northwest GT's Avatar
I've been happy with the Powerhouse aluminum driveshaft I've had for a few months now. I know it's pretty expensive, but I think they are the only outfit that actually has aluminum shafts in stock. I tried to get one from JPC, but they gave me the runaround for over a month before I figured out that they did not actually have the shaft for my auto. In fact, you can see this in the latest MM&FF where they rigged up a couple of cars. JPC said they still had "some problems" with their auto driveshaft. In fact, it wasn't even aluminum but steel. And this is about six months after I was trying to deal with them.
Powerhouse was good to deal with. No muss, no fuss, the shaft arrived in about 5 days and dropped in with no problems. I haven't had the car on a dyno, but I am sure the weight loss was helpful.
Old Sep 12, 2006 | 11:46 AM
I just got this in an email from http://www.driveshaftshop.com:
3" Steel, 23 lbs, 600HP (549.99)
3" chromoly steel 24lbs 1000hp (649.99)
4" Aluminum, 16.6 lbs, 600HP (699.99)
4" aluminum 17lbs 1000hp (to be announced)
Old Sep 12, 2006 | 12:54 PM
Does that mean they have the aluminum shafts, or that they will be available? The one they show on their website, I think, is probably chrome-moly steel.
Old Sep 12, 2006 | 11:07 PM
I sent them an email:
Are all three of these available?
and here's their reply:
hey
all except the 4" aluminum, they sold out but we will have them in about 2
weeks
Old Mar 25, 2007 | 11:31 AM
YaoNYC's Avatar
hello all,
i was checking out informaiton about the BMR carbon fiber driveshaft.
is it true that a better/lighter driveshaft releases 15+ rwhp?
thanks!
Old Mar 25, 2007 | 12:20 PM
subzero05's Avatar
Coast Has their new 4in aluminum shaft avail. I am running it now and have been very impressed!.. no clearance issues and the car revves up very quickly. I believe Tillman sells them.. The driveshaft shop ones are also very nice!
Old Mar 25, 2007 | 12:24 PM
YaoNYC's Avatar
thanks subzero. do you truly feel a significant rwhp increase?
in the order of mods where do you see this mod?
thanks again!
Old Mar 25, 2007 | 02:28 PM
scramblr's Avatar
I have Denny's DS sitting in my workshop waiting to go on.
http://www.dennysdriveshaft.com/html/ford_mustang.html
Old Mar 25, 2007 | 03:41 PM
YaoNYC's Avatar
that is awesome! let us know what happens. if you feel a noticable hp/tq increase.
r u going to dyno it?
Old Mar 25, 2007 | 05:05 PM
sublimaze's Avatar
i read there were issues with 4" alumimun ds + saleen short throw adapters. i don't want to give up my saleen adapter. does anyone know of a true aluminum ds smaller than 4"?
Old Mar 25, 2007 | 06:42 PM
Wharf Rat's Avatar
3 1/2 inch aluminum rated to 600hp...
http://www.lethalperformance.com/pag...riveshaft.html
Old Mar 25, 2007 | 07:10 PM
subzero05's Avatar
An actual HP increase will not show up on a dyno with a different shaft, I.e lighter one.. BUT, the engine works alot less to do the same job and the car get up in the RPM MUCH QUICKER with the new driveshaft so the Seat of the pants feeling is great..it is definately a worth while addition
Old Mar 25, 2007 | 08:23 PM
TillmanSpeed's Avatar
Former Vendor
Coast Aluminum Driveshaft is a GREAT piece. NOT just saying that because I sell them, because I have access to BMR, Powerhouse, and Driveshaft shop at CHEAPER pricing. The Coast Driveline is just REALLY a nice piece, and does a great job. For 589.99 to the door YOU CAN'T BEAT IT... it's 16 lbs. The competition weighs in at much more, we've tested both here in the shop. Aluminum has FAR better dampening characteristics than steel. And because it's 4" in diameter, it is more stable at critical speed. This is top grade aluminum tubes that are tested and balanced to within 1/8 of a gram! This unit's only downfall is that it can't be used with the saleen short shifter adapter (as mentioned above). It's a great driveshaft, and many people I can refer you to run it successfully.
CR
Tillman Speed
Old Mar 25, 2007 | 10:13 PM
ken3030's Avatar
I just had the Coast Alum Driveshagt installed. My installer seemed to like it. I have not seen any negitives from it. I have driven the car at least 300 miles. I have gone a 7.50 in the 1/8 mile at 92 mph and had the car upto 110 mph. It seems great to me I dont think you are going to find a better deal out there. JMO
I also had the car dynoed on a Dyno jet it made 502rwhp so I know the shaft can take at least that.
Old Mar 25, 2007 | 10:38 PM
YaoNYC's Avatar
CR
Tillman Speed
hi tillman,
that is a pretty good deal. how much would you estimate installation would cost?
thanks!
Old Mar 26, 2007 | 06:25 AM
Lowe!'s Avatar
Alright, I hope this doesn't throw things too far off topic, but there is one thing that was kept me from pulling the trigger on a 1-piece D/S. Do you HAVE TO HAVE an adj. UCA when you go from the stock shaft to a 1 piece??
In my case, I have the stock shifter, so no issues there. However, I do have Steeda (bad word) Ultralites on the rear. All this talk of pinion angle has me a little nervous about installing a 1-piece D/S.
Thanks for the input!
