Drag strip results: I need help/critique!
I went to the drag strip for the first time this week. I had a great time but my results were a bit disappointing: the best I could manage was a 14.170@101.6. The car is an '06 GT convertible with a Hurst shifter, JLT cold air intake and Bamachips 93 race tune so I expected to do better than that. Here are the results of all 8 runs ranked from best 1/4 mile to worst:
I did not do any preparation to the car like lowering tire pressure, removing the spare or running on 1/10th of a tank. But I did read up on all the tips here and at other sites and tried my best to follow them. One issue is that it was not possible to go around the water box in the left lane. However, it turned out the left lane was faster, so I don't think that was a factor.
I noticed that my back wheels got a little loose during the 1-2 shift. Does that mean I'm shifting too fast or too aggressively?
I also think I may be having trouble with the launch. I couldn't hear very well with the helmet on and so I may have been getting more wheelspin than I should have.
I'll stop rambling now. Thanks for looking and I appreciate any and all help.
Code:
# Time Lane R/T 60' 330 1/8 MPH 1000 1/4 MPH -- -------- ----- ----- ----- ----- ----- ----- ------ ------ ------ 7 10:42 PM Left 0.755 2.281 6.140 9.258 78.51 11.934 14.170 101.06 5 10:21 PM Left 0.932 2.279 6.144 9.268 78.22 11.956 14.199 100.85 1 9:05 PM Left 0.899 2.274 6.149 9.275 78.38 11.959 14.204 100.64 6 10:31 PM Right 0.462 2.366 6.239 9.358 78.54 12.031 14.267 100.93 4 9:58 PM Left 4.929 2.372 6.244 9.360 78.62 12.035 14.271 101.15 2 9:35 PM Right 0.621 2.250 6.148 9.307 77.09 12.022 14.285 99.73 8 10:45 PM Right 0.246 2.284 6.117 9.282 73.39 12.091 14.401 97.51 3 9:47 PM Right 0.652 2.474 6.386 9.508 78.56 12.180 14.418 100.82 ----- ----- ----- ----- ----- ------ ------ ------ Averages 1.129 2.323 6.196 9.327 77.66 12.026 14.277 100.34 Run #4: No driver in other lane - chaos at the tree! Run #8: Missed the 2-3 shift
Your 60' times are kind of high, you should easily be able to knock down 2.100, You've got the MPH so power is there, practice launching-give some stats on weather, humidity, and temp. Lets learn more.
Code:
I didn't record any weather data, but I'll definitely do it next time.
One thing that jumps right out at me was your 60' times. You should be able to get them to 2.1 with the stock tires, maybe lower. Also you didn't mention at what RPM you are shifting. I would be shifting at 6500 for 1-2 and 2-3 Practice Power Shifting if you don't already, and you should see your time drop. Based on the 60' you are spinning away alot of your time. Good luck!
I'm shifting at 6500 RPM, which is the new redline, courtesy of the Bamachips tune.
I felt like I was getting through the gears really quickly. I've got the Hurst short shifter and I'm not afraid to slam it around.
Thanks for the tips everybody! We're going again this Wednesday and I should be able to get some video to post. I'm also going to try to modulate the clutch more and dump it little less to see if I can get my 60 foot times down.
And don't worry about R/T either when you are trying to see how fast your car will go. Concentrate on the launch instead of stressing over the tree, the times will still show even if you have 1 sec reaction times. Just use the tree as a guideline, like a traffic light at a deserted intersection. It takes a ton of practice before you can get both a good launch and a good r/t. Being that track time is at a premium, spend the time on driving the car instead of competing with nobody.
That RPM worked well for me. Nowadays I launch at 5500-6000, or is that too high too?
you obviously are a veteran of the track, where as this guy needs to start low and work up. Then he could be a pro like you and launch at 5500-6000.
The avg person will clutch drop off the line, and you telling him 2800-3000 I felt was a little high.
