Drag racing question
Old Mar 15, 2005 | 04:11 PM
norcalmustang's Avatar
I'm going to the drags this weekened and had a quick question. I have a stick, and i shouldn't have to shift it to 4th gear when racin the 1/4 mile right?
Old Mar 15, 2005 | 04:18 PM
169stang's Avatar
what gears and do you have a tuned program? Okay, nevermind. If you are 4.10's/4.30's on the gears-1/4 mile, yes into 4th. No tune and at a 1/4 mile track, you will have to shift into 4th. It's right at 6000 rpm at the 1/4. If you have stock gears and a tune, you can stay in 3rd.
Old Mar 15, 2005 | 07:59 PM
O5GT's Avatar
i was well into 4th gear in the quarter in my 05 with just a predator
Old Mar 15, 2005 | 09:10 PM
169stang's Avatar
That don't sound right. Did you have your rev limiter removed or moved up? With the stock gears, and tune, I was finishing in 3rd right at 6000 rpm. My rev limiter is set at 6700 rpm so the gas doesn't cut out. 4th gear will cost you quite a bit. I currently have 4.10's and I do shift into 4th, but am getting 1.7's in the 60'.
Old Mar 15, 2005 | 09:20 PM
O5GT's Avatar
i cut a 1.85 60, trapping at nearly 104, rev limit is set at 6850 or so
i was shifting at 5800
Old Mar 15, 2005 | 10:35 PM
169stang's Avatar
With my tune, my peak hp is flat from 5800-6300, so I keep it in 3rd. Of course this is due to the time spent shifting results in hp loss, worse ET.
Old Mar 15, 2005 | 10:38 PM
O5GT's Avatar
i must have been doing something right, not too far behind you and i was on street tires, stock gear, no underdrives, no cai no nothing, just the diablo wheelhoppin down the track
Old Mar 16, 2005 | 07:30 AM
loudog's Avatar
05GT, what was your 1/4 ET?
Old Mar 16, 2005 | 08:01 AM
O5GT's Avatar
13.21 stock everything, hc trap, tires, etc etc, no weight reduction, everything still in the car including my 260lb self, only thing done was the predator
Old Mar 16, 2005 | 11:32 AM
Purple Hayz's Avatar
you are running VERY strong for such minimal mods. practically knocking on the door to 12s. My guess is you either have a factory freak, an outstanding tune, exemplory driving skills, or some combination thereof. In any case, congrats
Old Mar 16, 2005 | 02:47 PM
-FROG-'s Avatar
What were the track conditions? hot, cold, altitude? What state?
Old Mar 16, 2005 | 03:55 PM
169stang's Avatar
Don't get me wrong, those are great numbers. I just know that if you're shifting into another gear, it'll cost you time. Do you have a dyno graph of your car. It will tell you what your peaks are and where you should be shifting. That's what I've gone by atleast.
Old Mar 16, 2005 | 06:14 PM
O5GT's Avatar
havent had a chance to dyno it
track conditions were horrible as it was opening day at beech bend raceway, temp was around 70 or so,
Old Mar 16, 2005 | 07:05 PM
loudog's Avatar
[/quote]
Wow! That is quick for stock with a tune...I agree, you must have gotten lucky and grabbed one of the "freak" cars putting out phenomenal power!
Old Mar 16, 2005 | 08:24 PM
elvism's Avatar
[/quote]
in april issue of mm&ff they got 13.395 and 101.87 w/1.996 60 foot. bone stock.
Cdvision
Sep 5, 2015 05:22 PM
BavarianStang
Sep 5, 2015 05:55 AM
Sep 2, 2015 07:33 PM
